There is also a company called "Ancor" which seems to have quality boat wiring, electrical parts, etc.
If I understood the "bonding" segment correctly, it stated that ALL thru hull fittings, in addition to normal things like the engine, alternator, prop shaft, prop, etc., must be connected and bonded to a sacrificial metal (zinc). This was puzzling to me.
As we all know, I have looked at more than a few Cape Dory sailboats and I cannot recall seeing where all of the thru hulls were "bonded". For example, in the CD 25D, there are at least two thru hulls for the marine head (salt water flush in and waste discharge overboard). I have not observed any green wires running from these thru hulls to an area in the bilge which is then connected to the sacrificial "zinc plate" which I think is located on the hull outboard from the bilge on the starboard side.
On the CD Typhoon Weekenders I have looked at, there are two thru hulls for the cockpit drains. Again, I have not observed any green wiring from these thru hulls to a sacrificial zinc plate.
I tried researching this issue on the board’s search function. I could not find any specific discussion of this issue although several years ago a few folks posted comments suggesting that thru hulls were not "bonded" on their Cape Dory sailboats but no discussion of why not.
I also tried doing a Google search and read Don Casey's discussion of sacrificial zincs. However, unless I missed it he did not discuss thru hull fittings.
My question is: Are all thru hulls supposed to be "bonded" to a sacrificial zinc
Is it possible that because the thru hull fittings I have looked at on Cape Dory sailboats are made of only one metal (bronze) that there is no galvanic corrosion and thus no need for zinc:?: However, if this is so, what about all of the stray electrical current in the water, especially at mooring fields
I would be grateful for any explanations, etc. Please remember in submitting your response(s) that you are dealing with a dummy and try to use simple words.
Thanks in advance for the education.
