Typhoon Rudder Shaft-to-tiller slipage
Paul D.
Post by Paul D. »
Does anyone know a simple, effective method to stop the tiller from slipping on the shaft? My rudder shaft has a worn spot on it from the set bolt and while I don't think the thing will slip all the way round, the feeling is not pleasant! I do not want to just keep tightening the bolt and strip the rudder cap in ignorance!
Paul Danicic
HORNET
MPLS
nyeme001@tc.umn.edu
Bob Wessel
Re: Typhoon Rudder Shaft-to-tiller slipage
Post by Bob Wessel »
Paul D. wrote: Does anyone know a simple, effective method to stop the tiller from slipping on the shaft? My rudder shaft has a worn spot on it from the set bolt and while I don't think the thing will slip all the way round, the feeling is not pleasant! I do not want to just keep tightening the bolt and strip the rudder cap in ignorance!
Paul Danicic
HORNET
MPLS
Years ago, I had same problem. I drilled and tapped a hole in the shaft, then screwed longer screw into the shaft. Worked for me. Good luck.
Bob Wessel
Swabo71@webtv.net
