Hull speed
Guy Senter
Hull speed
Post by Guy Senter »
I would like the formula for hull speed of a displacement sailboat(as a function of length). I want this so I can get feel for distances small sailboats can be expected to travel during a weekend. Any other
information on typhoon weekend cruising range would be appreciated.
guynapex@att.net
Bob Luby
Re: Hull speed
Post by Bob Luby »
The textbook formula is 4/3 X Square root of Load Water Line in feet.
i.e on a boat with a 25 foot **waterline** this would be about 6.66
kts ( roughly ). Heeling has the effect of lengthening the waterline
so a boat may sail somewhat faster when heeled.
Note! waterline length is not "length over all", which is what people
use to describe boat lengths. A 25 ft LOA boat may have a LWL of
20 ft or less. Check the specs on the Typhoon here.
What really affects cruising are tidal currents. In LI Sound, where I sail, my peak speed over ground can range from 0 or negative kts,
( sailing through Plum Gut against the tide ) to 9 or 10 kts.
( sailing through Plum Gut with the tide. ) From a powerboater's standpoint sailing is really controlled drifting, I suppose.
My rough guess would be 4 - 5 kts max.
Typhoon owners?
Rluby@aol.com
Arnold Amenda
Re: Hull speed
Post by Arnold Amenda »
Guy Senter wrote: I would like the formula for hull speed of a displacement sailboat(as a function of length). I want this so I can get feel for distances small sailboats can be expected to travel during a weekend. Any other
I believe the formula is: (the square root of the waterline length in feet) x 1.34 = hull speed in knots. In Puget Sound I calculate 3 Kt for 8 Hr = 24 mi per day for cruising my Typhoon Daysailer. With fair winds I have made up to 40 mi in a long day. My best velocity made good is 8.1 Kt by GPS with some following current under masthead spinnaker and 20 Kt following wind. I made 24 mi. in 4 hours. That was a great ride for my Typhoon. But I plan on 24 mi per day.
aamenda@ix.netcom.com
M. R. Bober
Re: Hull speed
Post by M. R. Bober »
1.34 time the square root of the length of the waterline is the generally accepted formula. Remember that the waterline length increases as the boat heels.
Catherine Monaghan
Re: Hull speed
Post by Catherine Monaghan »
Guy,
You can use this <a href="http://www.image-ination.com/sailcalc.html">sailboat calculator</a>. It will provide you with more information than just the hull speed of your boat.
catherine_monaghan@merck.com
CD32 Realization
Raritan Bay
