I'm using shutterfly for uploading pictures. The pics are the right size and are .jpg hower the URL ends in .jsp I
then used the URL button because you can't use Img unless ends in .jpg or .gif or .png.
When I use the URL code the website pops up to my sign in spot. Am I supposed to give out my password in order to have viewers see my pics?
Mark
using shutterfly for photos
Moderator: bobdugan
- Cathy Monaghan
You must "share" photos first....
Do not share your password with anybody!
Normally, unless you're using PhotoBucket.com, most online photo services require that your "share" photos via e-mail. What you need to do is share the photo with yourself so that you get the e-mail. The URL contained within the e-mail is the one that you use in a message board posting and the file name for the photo should have a jpg, gif or png extension. And you'll be able to use the IMG tag. This works with photos only. If you share a photo album, then you'll need to use the URL tag.
Hope this helps,
Cathy
CDSOA Webmaster
Hope this helps,
Cathy
CDSOA Webmaster
