Running rigging question
Tom Kennedy
Post by Tom Kennedy »
Folks,
I'm replacing the 1/2" jib and main halyards with 5/8" line on our CD-26. There doesn't appear to be any drag through the shreaves with the meatier line. Has anyone encountered any problems or drawbacks that I should be aware of?
Tom K.
Gary M
1982 CD22
Marina del Rey, CA
5/8th inch line on a 26?
Post by Gary M »
Hi Tom,
If there's no drag, I can't see a problem but that sounds like some really heavy line for your boat. What made you make the change?
Gary
drysuit2
Location: Segue, 1985 Cape Dory 26 Hull # 15 Port Washington NY
CD26 halyards
Post by drysuit2 »
I have also been replacing my sheets and halyards a little at a time. The CD26 originally came with 3/8” halyards. So while you probably did fine with ½”… I would think that the 5/8” is overkill. I can understand why you would want a thicker line on your sheets [easier on the hands]. But I would think a 5/8” halyard would add extra weight aloft [where you don’t want it]. Plus add extra windage aloft. Unless you got the rope for free, I’d stick with the smaller diameter. But the sheaves [like everything else on a CD] seem over sized, so you could probably get away with it.
Hope this helps
Tom Kennedy
running rigging
Gary,
I believe we came across a good deal on line and in my mind at that time, 1/2" seemed too thin. I still have the option of buying 1/2", as the shackles aren't spliced on yet, but then I'll probably end up having the 5/8" stuff laying around for years taking up space. Tom K.
drb9
Post by drb9 »
Not to change the subject too much, but I still have two halyards on my mast, one for the main, and one, I think, from before the boat had roller furling (added before I bought it). Is there any need for that other halyard? I've never figured out exactly what the ends of the whisker pole attach to. Should that halyard be used to support one end of the pole? Or, should I reverse the direction of the halyard so I have a spare for the main?
Thanks.
Darin
Dick Kobayashi
Halyard
Post by Dick Kobayashi »
Darin, I believe the halyard is probably for a spinnaker or similar head sail.
Dick K
CD 25D Susan B #104
Mattapoisett, MA
Neil Gordon
Post by Neil Gordon »
drb9 wrote: Is there any need for that other halyard?
If/when you need to go aloft, a second halyard is a good thing to have. Use it as a safety line if you go aloft using the main halyard or as a primary if the main halyard shackle works its way up to the masthead on its own.
When you talk about reversing it as a spare main halyard, is it a wire/rope combination? Otherwise, what's to reverse?
Tom Kennedy
running rigging
Frank,
Thanks for the response. I didn't realize the original lines were 3/8". Just for the record, I decided to stick with using new 1/2"line. Why fix what isn't broke?
Darin,
Having an additional halyard is a wonderful thing. At our club we launch boats by backing down a ramp. The furlers have to be disconnected so the extrusion doesn't swing into the cross member on the lift. The extra halyard secured to the deck cleat serves as a forestay during launching.
Tom K.
iropicc
5/8" line
Post by iropicc »
HI TOM, YOU WON'T HAVE THAT LINE LAYING AROUND FOR YEARS IF YOU SEL IT TO ME, FOR USE AT THE NAV STA MARINA 361-878-3537
Gary M
1982 CD22
Marina del Rey, CA
I agree with the decision
Post by Gary M »
Tom,
I really understand the feeling of grabbing on to some nice size line but 1/2 inch is some nice size line! I would do the same and just keep the half inch.
I remember talking to a friend on a similar subject and he said, "I'm not trying to lift a Volkswagon with it!"
Gary
