CD27 Repower
- Bob DuPont
Pelican
Hull 182
Miami, Florida
CD27 Repower
Anyone repower their CD27 with the Westerbeke 20B Two? Any thoughts, suggestions, warnings? Do you have any pictures to share? Does it fit through the companionway without modifications (read: cutting) of the companionway? What prop did you go with? So many other questions, but you get the idea. Thanks.
Bob D
Hallandlale Beach, FL
Bob D
Bob D
Cape Dory 27
Hull 182
"Pelican"
Cape Dory 27
Hull 182
"Pelican"
Check out Betamarine
I have a Westerbeke 13 in my 27 that is being "seriously serviced" after 24 years of faithful service. Initially the plan was to remove the engine so the mechanic could have easy access to it and also give me opportunity to redo the engine compartment - sound deaden, remove some old wiring, relocate equipment, etc.
When the time came (last week) to remove the engine the cost became probibitive -- too much stuff had to be removed from the engine to get it out of the compartment (and back in when the time came). The mechanic and I elected to leave the engine in place rather that spring for the many man-hours (@ $68) to go through this exercise.
While this was going on I stopped by the Betamarine distributor to get info on their products "just in case." Having seen some nice Betamarine installations I had never seen one of their engines out of a boat so this was an education. The small size of the 13.5 h.p. BZ-482 (3 cyl) impressed me. Built on a Kubota block, the Beta engines are designed from the outset for marine use with all the service points on the front of the engine -- no trying to check or change the oil by braille, for instance. Beta also rates their horsepower at the tailshaft which few of the other manufaturers do, opting for a "no load" test instead.
I would certainly consider the Betamarine as a candidate for repowering if I were in the market.
Hope this helps.
________
HERBAL SHOP
Hope this helps.
________
HERBAL SHOP
One more thing ...........
Left out a significant piece of info -------- perhaps the nicest feature of the Beta engines is the engine mounts. They use a 4-point mount that greatly simplifies any modifications to the boat's existing engine beds.
Having done a number of repowering jobs this is a real benefit.
________
Herbalaire Vaporizers
________
- Bob DuPont
Pelican
Hull 182
Miami, Florida
Thanks for the Beta Marine suggestion. I've searched out all the past discussions of repowers on the CD board and must say that the prospect of repowering is quite daunting. So daunting that we actually shied from it and put Pelican on the market. However, each time I went down to show her, it got harder to envision closing the sale. She is just too pretty and sails too well to part with.
Our mechanic is certified for Yanmar, Westerbeke and a slew of others. He proposed going the Westerbeke 20B Two or Universal M3-20B. He said he likes the engines (actually likes the Universal better because the three cylinders make it smoother running), the company's service and the price, which is especially good right now with the Miami "boat show special" that includes the starting panel for about $5,900 on the Westerbeke, and $6,200 on the Universal.
We really don't need the extra two horsepower or 25 pounds of weight of the Universal, so we are leaning toward the Westerbeke.
There is a CD27 for sale on Yacht World with a new 20B Two, and the very kind broker said he would shoot some pics of the installation to send me as an introduction to the possible modifications we could be facing.
I also really like our mechanic. He has never been one to throw (our) money at a problem. So, I am inclined to go with his suggestions from that point also.
Of course, there will be extra expenses with this, starting with adjusting the engine bed, not to mention adding a raw water strainer, new prop for the RH turning shaft. He said he hopes to save the shaft, but that depends on the position of the engine. We also plan to do what is necessary on the stuffing box. And, may as well install a new Racor fuel strainer/separator to replace the original equipment strainer for the dying YSM8.
I will assist in this project (I'm a really good gofer, carpenter and painter) so that should help on the cost. But we're still budgeting $10,000 (it's worth dreaming, right?).
Now if we can get this done before hurricane season, all will be well in the world.
Bob D
Cape Dory 27
Hull 182
"Pelican"
Cape Dory 27
Hull 182
"Pelican"
- Ben Thomas
Re power
Some work on the stringers is always necessary (99% of the time) when repowering with a different engine. Sometimes difficult sometimes easy. An educated roll of the dice.
The easist repower I have seen is replacing the Atomic four with the Betas. A4 feet come as a no cost option replacing standard mounts. I have had many customers bolt the engines right up with no hassles.
The BZ482 and the BZ602 13.5hp & 16hp respectively. would work, both 2cyl. engines.
Betas & their options are available to board members @15% off with free drop shipping on the east coast.
Catherine added my offer in the where to look link.
Not wanting to catch flak.. just a reminder.
Ben Thomas Oregon Marine Industries (Beta-Marine dealer)
Milagro CD-30 #248
Milagro CD-30 #248
