Typhoon question
MikeG
Typhoon question
Post by MikeG »
This might be the stupid question of the month. I am rebuilding a typhoon. There are wooden disks that cover the access hole to the chainplates. What holds these in? The boat had a plumbers caulk on the wooden disks to hold them in. Is this correct? Next question. What does the cover to the bilge hole look like. Is it also a wooden disk or a square piece of wood.
Told you it was stupid but I wanted to go back as close to original as I can.
Mikeg
Mike G
Peter Drake
1974 Typhoon Weekender #672,
Marblehead, MA
Typhoon interior teak
Post by Peter Drake »
Hi Mike:
On my '74 Typhoon Weekender, I have a square teak piece, with a thumb hole, covering the bilge access. The two teak chainplate access covers, after refinishing with Cetol, were fixed with a thin bead of 3M 4200.
P-[/i]
slaume
plumber's caulk
Post by slaume »
Hi guys, Peter you may be right to use a bit of 4200 but I believe the plumber's caulk is original. I always thought it was a funny way to hold in the covers. It does seem to work and is fairly easy to remove and even replace with the same old caulk. I used a few dabs of 4200. The bildge cover is a square of 3/4" teak with the edges rounded over including the lifting hole which is about 3/4" centered in the piece. I still want to get a look at Wharf Rat on of these days. Only a beautifully maintained boat could get away with a name like that. Happy sailing, Steve.
Neil Gordon
Re: Typhoon question
Post by Neil Gordon »
MikeG wrote:This might be the stupid question of the month.
If you define "stupid" as asking something you just don't know yet, this month is already taken.
winthrop fisher
cd 22 "Easy Rider Sr" 84
Post by winthrop fisher »
Hi Mike....i could them out and put speakers in its place, it work great for five inch speakers.... you don't need them...winthrop
MikeG wrote:This might be the stupid question of the month. I am rebuilding a typhoon. There are wooden disks that cover the access hole to the chainplates. What holds these in? The boat had a plumbers caulk on the wooden disks to hold them in. Is this correct? Next question. What does the cover to the bilge hole look like. Is it also a wooden disk or a square piece of wood.
Mikeg
winthrop fisher
hey...sorry type oh, mine were a tight fit it for a long time, then i put in a am/fm/cd and put the speakers in there place and two in the cockpit as well. it has great sound. and it did not cost that much....winthrop
winthrop fisher wrote:Hi Mike....i took them out and put speakers in its place, it work great for five inch speakers.... you don't need them...winthrop
Mikeg
