[img]http://img.photobucket.com/albums/v56/C ... 04-056.jpg[/img]
1984 CD 31 #51 "Mary Alice" is up for sale due to financial need.
This exceptional cruising yacht has been continually upgraded since the year 2000.
Engine replaced (2001) with Betamarine BD722 (currently 996 hrs).
Balmar 65amp Alternator, Smart Regulator, 300 Amp/hr AGM house bank, 110 Amp/hr AGM start/windlass bank.
Topsides Awlgripped Flag Blue. Deck, cabin-top, cockpit Awlgripped Oyster White with new non-skid surfaces.
New UK mainsail and Yankee '04. Loose foot Main with out-haul control line led aft to cockpit.
Custom Navy blue Dodger, Bimini and connector '04.
Espar cabin heater.
New Maxprop feathering propeller '03.
Switlik "Rescue Pod" life raft, serviced and certified 7/05.
Insulated backstay for SSB antenna.
AquaSignal masthead tricolor/anchor light /emergency strobe '04.
Barrier coated (Interlux 2000) bottom with Copperpoxy long term antifouling surface '04.
New Lewmar electric windlass with bowsprit chain protector plate, chain stopper with 35lb CQR, 150' chain+150' nylon, controlled by hand-held remote with plugs on bow and in cockpit.
<img width ="540" src="http://img.photobucket.com/albums/v56/C ... 1_0165.jpg" alt="Image hosted by Photobucket.com">
Helm mounted teak enclosure with RL70CRC color Raymarine radar/chartplotter '03, and Questus backstay mounted 18" radome.
Helm mounted teak enclosure with engine instrument panel '04. Panel stays dry and operative even if cockpit fills with water.
Helm mounted Raymarine ST4000+ autopilot control head '04.
New key-lock lid closures on all 3 cockpit lockers (visible in background below engine panel).
Bose 131 recessed cockpit speakers with water tight covers (visible near floor at forward end of cockpit).
<img width ="540" src="http://img.photobucket.com/albums/v56/C ... 1_0167.jpg" alt="Image hosted by Photobucket.com">
ST60 Tridata and Wind instruments flush mounted on stbrd bulkhead with new masthead and hull mounted transducers.
Full set of cockpit cushions, Oyster white Sunbrella with Navy piping.
Custom cockpit shower.
<img width= "540" src="http://img.photobucket.com/albums/v56/C ... 1_0186.jpg" alt="Image hosted by Photobucket.com">
Teak pin rail with bronze belaying pins on port bulkhead.
New Harken 16ST and Andersen 28ST winches for main halyard and main and staysail sheets with 5 Spinlock XAS rope clutches on cabin top for sail handling from the cockpit.
New Harken 32.2 two speed self-tailing foresail sheet winches on coaming.
<img width="540" src="http://img.photobucket.com/albums/v56/C ... 1_0168.jpg" alt="Image hosted by Photobucket.com">
Custom, "lift-away" staysail boom allowing an unobstructed foredeck with roller furled staysail and Yankee.
<img width="540" src="http://img.photobucket.com/albums/v56/C ... 1_0171.jpg" alt="Image hosted by Photobucket.com">
Galley and Head: hot and cold pressure water with Sensor Max Variable Speed fresh water pump, Isotherm "Self-Pumping" ASU holding plate refrigeration, Origo gimballed two burner alcohol stove with oven, Seagull charcoal water filter with separate faucet. Seawater "tip-toe" foot pump with separate faucet.
<img width="540" src="http://img.photobucket.com/albums/v56/C ... CF0481.jpg" alt="Image hosted by Photobucket.com">
Other features include mirror finish exterior varnish, satin finish interior varnish, beige, glove leather settee upholstery, individual dimmer controlled cabin reading lights, dimmable night vision (red) and clear cabin dome lights, macerator pump-out for holding tank, water tank level sensors on custom teak inner bulkhead panel.
<img width="540" src="http://img.photobucket.com/albums/v56/C ... 1_0172.jpg" alt="Image hosted by Photobucket.com">
Also on this panel are a Link 20 battery monitor, two bilge pump switches, one of them an Aqualarm with counter, Espar cabin heater control, autopilot remote plug, and 12VDC and 110VAC outlets and the refrigeration control panel.
[img]http://img.photobucket.com/albums/v56/C ... Alice1.jpg[/img]
Has spinnaker with snuffer "sock" and will definitely travel.
This unique offering is being made first to the readers of this board. No sales tax on Rhode Island boats.
$69,000 reasonable offers considered.
contact rerskwin@netscape.net for more info.
CAPE DORY 31 FOR SALE
