winterizing outboards
frank
Post by frank »
ok it doesnt freeze out there in sunny california.
but if any one knows about winterizing the cooling system
for a 5 year old mercury outboard ( efi 200 )
i have taken the boat out today and it overheates , doesn't seem to be pumping water and when i used it last oct 1998 it was fine.
help from roswell nm
frankr@lookingglass.net
Bob Ohler
Re: winterizing outboards
Post by Bob Ohler »
Frank, I'd bet you either have a blockage or need a new impeller, and I'd bet it was an impeller, especially if the one that is in there now is the original.
frank wrote: ok it doesnt freeze out there in sunny california.
Dana
Post by Dana »
Frank,
Bob is right. Impellers can go on you in a flash. If it has not be changed in the past 5 years it has seen a good life. You will want to have the lower unit dropped and change out the water pump internals. Usually about $35 for a typical kit. Also if you have not changed out
the thermosat, now is a good time too.
Dana
darenius@aol.com
