Bow Roller
Phil Shedd
Rothesay NB Canada
Membership # 89
Bow Roller
Post by Phil Shedd »
[img]http://images.kodakgallery.com/photos11 ... _0_ALB.jpg[/img]
The port bow roller broke last fall and thought it would make a good late winter project to make some new ones. I removed the olds ones and found that brass shaft was bent so changed that also.
I make the rollers my self using 3" aluminum stock. I turned them down to a size as close as the old plastic ones. I kept the inner diameter a little bigger to reduce wear and make it a little easer to pull on. The rollers are drilled 32/64 with the shaft 1/2". The new shaft is stainless 306 .
As you can see I put them back in place to show you what they look like. I still have to do the bright work this year so the wood plugs have not been put back.
A fun project took about a three nights to make the rollers. Next battery box for new started battery.
Phil
Paul Kamins
Bow rollers
Post by Paul Kamins »
Beautiful!
