The boat has been neglected but is still sailable. The owners are asking $2000. Too much or just right? Here are her specs as I know them:
1) Typhoon. Circa 1983?
2) Starboard rub-rail is damaged and, about 3' from the front is demolished. Apparently from breaking her moorings during the No-name storm in this area several years ago.
The owners claim the hull to deck joint is not affected and remains sturdy.
3) She has 2 sets of sails in (and I quote) "Servicable" shape.
4) A trailer
5) The large teak rails to which the winches are attached are black from being ignored and have weathered to a point where they are very rough to the touch. Grooved along the grain in fact. Should I wonder about their strength?
6) She has been run aground (sand) far enough along the keel that the rudder popped out from the upward pressure. This I assume is normal and no big deal, but near the bottom pintle, just in front of where the pintle-plate is attached to the keel is a material that has a 'crumbly plaster' look and would crumble if I picked on it with my finger, I suspect. What is the material and is it something to worry about or just get fixed?
7) There is a 1 sq ft section on her amidships (starboard again) where there is a stress fracture (all parallel lines) in the gel coat, just above the water line. The hull however seems okay...
8) An owner installed pulpit has stress cracks around the pulpit stanchions. Potential leaks, or just unattractive? I brought a flash-light for my interior inspection and noticed pretty small washers for most of the backing nuts on the bolts and no nuts at all on some of the bolts...
9) She needs paint. Badly. Her below the waterline look sports 2 large sections where the trailer supports were when the owners last tried to paint her. Not exactly sporty.
A long list, but please help where you can. I love the boat's design and dont mind the hard work to fix her, but I want to sail her while I work on her, not watch my bank account succumb to my ignorance.
Brett.
freebs@tampabay.rr.com
