Tiller Attachment Fitting
Don Kolenda
Post by Don Kolenda »
Pardon the (lack of) correct terminology ... The tiller on our 74' CD25 (#76) has a lot of play in it. I went to replace / tighten the long bolt in the fitting attaching it to the post coming up thru the cockpit sole, etc but found that the holes in the the bronze fitting itself were "abraded open from friction" over the years (signs of bronze 'dust') such that the holes are now bigger the the bolt itself and thus the origin of the play in tiller. Bigger bolt doesn't work for numerous reason as a long term repair. Seems like that fitting needs to be replaced (?). Any sources (and name) for this piece or other suggestions. She's being tucked away now for winter in our yard and I'm taking inventory of stuff to get/buy thru the upcoming winter.
Don_Kolenda@msn.com
Duncan Maio
Re: Tiller Attachment Fitting
Post by Duncan Maio »
Don Kolenda wrote: Any sources (and name) for this piece or other suggestions
The tiller strap and cap assembly is available from Spartan Marine for around $150. The part number varies depending on the size of the rudder shaft. 800-325-3287
Duncan Maio
s/v Remedy
CD 27 #37
dmaio@att.net
bob loewenstein
Post by bob loewenstein »
Don Kolenda wrote: The tiller on our 74' CD25 (#76) has a lot of play in it. .... but found that the holes in the the bronze fitting itself were "abraded open from friction" over the years (signs of bronze 'dust') such that the holes are now bigger the the bolt itself and thus the origin of the play in tiller.
You could find someone locally to reweld the bronze so the holes are the correct size. A friend of mine did this himself for his cd28.
rfl@yerkes.uchicago.edu
Don Kolenda
Duncan Maio
s/v Remedy
CD 27 #37
Thanks, Duncan. Exactly kind of info I was search for.
Don Kolenda@msn.com
Tim Dean
Post by Tim Dean »
Don Kolenda wrote: Pardon the (lack of) correct terminology ... The tiller on our 74' CD25 (#76) has a lot of play in it. I went to replace / tighten the long bolt in the fitting attaching it to the post coming up thru the cockpit sole, etc but found that the holes in the the bronze fitting itself were "abraded open from friction" over the years (signs of bronze 'dust') such that the holes are now bigger the the bolt itself and thus the origin of the play in tiller. Bigger bolt doesn't work for numerous reason as a long term repair. Seems like that fitting needs to be replaced (?). Any sources (and name) for this piece or other suggestions. She's being tucked away now for winter in our yard and I'm taking inventory of stuff to get/buy thru the upcoming winter.
Don,
Check with Kim Houghton at Rig-Rite in RI. 401.739.1140 or Box 163
East Greenwich, RI 02818. These guys have a wide variety of Cape Dory
hardware. Be prepared to give measurements. Shipping is fast also.
TDeanCo111@aol.com
