Dorade Vent Hoses for Cape Dory 25D
- Zeida
- Location: 1982 CD33 "Bandolera II" Hull #73Key Biscayne-Miami, Florida
Re: Dorade Vent Hoses for Cape Dory 25D
Mitch, did you use all 50 ft? I need 25 ft. for my CD-33. If you want to sell some of it, I will gladly buy it from you.
zeida
zeida
Zeida
- M. R. Bober
I'll measure what is left, but I suspect it is less than 25 feet.Zeida wrote:Mitch, did you use all 50 ft? I need 25 ft. for my CD-33. If you want to sell some of it, I will gladly buy it from you.
zeida
Mitchell Bober
Sunny Lancaster, (Where it is absolutely beautiful today.) VA
CDSOA Founding Member
- M. R. Bober
FWIW: Generally the exhaust hose is placed lower in the bilge than the input. Certainly that is the case with a gasoline engine and probably if you use propane for heating/cooking. The idea is to remove those heavy fumes from the bilge. The Coast Guard has an opinion on this subject, which is oriented towards gasoline powered vessels, but may well be their standard. http://www.uscgboating.org/assets/pdf/recalls/BSC69.pdfSteve Laume wrote:tjr818 wrote:$6.00 a foot for the Trident seems a bit out of my reach. Grainger sells similar types in 25 foot lengths for around $5.00 a foot (still too much for meSteve Laume wrote:...I had some dust collector hose that I use in my shop so that is what I used. It seems very similar to what Russel posted and is nice to work with... Steve.).
In my shop I have 4" and 2 1/2" dust collection hose, but no 3". Which size did you use Steve? Did you need an adapter?
http://www.blastgateco.com/Flex-Hose.php
I think the stuff I used was probably something like the T4 Econo Hose. This is not the company I dealt with and it was a long time ago that I ordered it but there are lots of great hose choices out there. This was just the first Goggle hit I had on "dust collector hose".
I ran one long hose and one very short one that terminated at about the level of the cockpit sole. The idea was that the high one would be the exhaust. It takes less hose and I belive it is more effective, Steve.
Mitchell Bober
Sunny Lancaster, (Where one fewer explosion on your boat is a good thing!) VA
Good point Mitchell but the only gasoline on board Raven is stored at the mast. I am running diesel and CNG which is lighter than air. So at least in my case the heat and fumes are what I am trying to evacuate. There are no explosive fumes to settle into the bilge. I even have a charcoal grill and not propane, Steve.
- M. R. Bober
Steve,Steve Laume wrote:Good point Mitchell but the only gasoline on board Raven is stored at the mast. I am running diesel and CNG which is lighter than air. So at least in my case the heat and fumes are what I am trying to evacuate. There are no explosive fumes to settle into the bilge. I even have a charcoal grill and not propane, Steve.
If there is a need, you can always rotate both cowls 180 degrees.
Mitchell Bober
Sunny Lancaster, (A great place to sail home to.) VA
- tjr818
Maybe this belongs in the locked vs unlocked prop thread, but here goes, which way does the air flow through the cowl vents? Running, reaching, close hauled ???M. R. Bober wrote:If there is a need, you can always rotate both cowls 180 degrees.
Mitchell Bober
I keep one opposite the other just because it seems that at least one of them will always have positive pressure (but I'm not positive
- M. R. Bober
tjr818 wrote:Maybe this belongs in the locked vs unlocked prop thread, but here goes, which way does the air flow through the cowl vents? Running, reaching, close hauled ???M. R. Bober wrote:If there is a need, you can always rotate both cowls 180 degrees.
Mitchell Bober
I keep one opposite the other just because it seems that at least one of them will always have positive pressure (but I'm not positive)
The forward facing vent, the intake, should be connected to the "higher" hose in the bilge (unless you are Steve
![Wink ;-)](./images/smilies/icon_wink.gif)
The exhaust vent, facing aft should be connected to the "lower" hose (again unless you're Steve.)
Mitchell Bober
Sunny Lancaster, (Where I'm exhausted.) VA
- tjr818
Well...? What if Steve and I are sailing straight downwind? Doesn't the "exhaust" hose then become the "intake" hose, and the "intake" become the "exhaust"?M. R. Bober wrote:The forward facing vent, the intake, should be connected to the "higher" hose in the bilge (unless you are Stevetjr818 wrote: Maybe this belongs in the locked vs unlocked prop thread, but here goes, which way does the air flow through the cowl vents? Running, reaching, close hauled ???
Mitchell Bober
This is exhausting
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
It might also depend on what you are trying to exhaust.
It would depend on weather, heavier than air, explosive, vapors are your primary concern, or it is heat you are trying to eliminate. If I am sailing down wind, the engine is not running and I am not too concerned with ventilation. If I am motoring, weather it is in a no wind condition or I am motor sailing into wind right on the nose the forward facing vent is always the intake.
Who knew cowl vents could become such an exhausting and controversial thread, Steve.
I don't think I have ever in my ownership of the boat cared which direction they are facing, nor adjusted them. Once faces forward and one aft, and I couldn't tell you which is which without looking. I have no doubt everyone could take this same attitude and be none the worse for it!
My prop freewheels by the way.![Wink :wink:](./images/smilies/icon_wink.gif)
Russell
