hi,
all i can say is rebed all your hardware and check your prop shaft and thru hull fitting.
but, when i had that last leak it lasted for months until i took the boat out of the water and found the thru hull fitting was crack on the out side of the boat and let water into the bilge.
winthrop
What causes leaks in a 28?
- winthrop fisher
cd 22 "Easy Rider Sr" 84
