The Log of Typhoon "Dory"
Re: The Log of Typhoon "Dory"
Please do keep the posts coming Jim. This is the only "sailing" that we get to do when it is 17º outside.
wikakaru
Post by wikakaru »
Ben Miller wrote:I've been appreciating your posts, Jim, although with a tinge of jealousy. I try to distract myself from that by paying attention to the details in your photos. I notice that you seem to have your leads tuned about where I do--right at the forward end of their travel. I notice also that your jib sheets are quite a bit thicker than mine are. That seems like it would be an advantage when running the genoa sheets around the winches and cleating them off.
Thanks! I'm glad you've been enjoying them!
I'm not sure if you are talking about the jib (cabin top) or genoa (toe rail) tracks and leads; I suspect it's the genoa, as you mentioned running sheets around the winches, and I only use the winches for the genoa. (My jib sheets are secured by cam cleats on the cabin house.) Unfortunately on both my jib and genoa the lead positions need to be farther forward than I am able to put them. The tops of both sails always luff before the bottoms. Ideally, the leads would run to the aft end of the track when close-hauled, and could be eased farther forward when bearing off the wind. I even had my sailmaker re-cut the jib to move the lead farther aft, but it still is too far forward for proper sail trim.
One of my wish list projects is to refinish the decks (they have those little randomly-oriented gelcoat cracks that many Cape Dories suffer from) and at the same time make the jib and genoa tracks extend farther forward.
Our sheets are much larger in diameter than are needed strength-wise. The manual calls for 5/16"—I don't recall what mine are—but the larger lines are easier on the hands.
Smooth sailing,
Jim
wikakaru
Post by wikakaru »
tjr818 wrote:Please do keep the posts coming Jim. This is the only "sailing" that we get to do when it is 17º outside.
In that case, here's the log from Saturday:
2022-02-26 Dory Log 6.5-inch.jpg (1.19 MiB) Viewed 6315 times
2022-02-26 Daysail Dory Pensacola.jpg (900.6 KiB) Viewed 6315 times
Smooth sailing,
Jim
wikakaru
Post by wikakaru »
Dory's February Sailing Summary
12 Days of sailing (a new record for February, beating out February 2018's old record of 11 days).
36 hours 29 minutes under way.
129.3 miles logged.
Here are the tracks of all of February's sails:
2022-02-28 Dory February Daysails (12).jpg (674.34 KiB) Viewed 6311 times
Smooth sailing,
Jim
wikakaru
Post by wikakaru »
2022-03-01 Dory Log 6.5-inch.jpg (2.52 MiB) Viewed 6311 times
wikakaru
Post by wikakaru »
2022-03-02 Dory Log 6.5-inch.jpg (1.36 MiB) Viewed 6308 times
wikakaru
Post by wikakaru »
2022-03-03 Dory Log 6.5-inch.jpg (2.17 MiB) Viewed 6300 times
Smooth sailing,
Jim
Brimag
Post by Brimag »
Nice job. !!
wikakaru
Post by wikakaru »
2022-03-10 Dory Log 6.5-inch.jpg (2.82 MiB) Viewed 6290 times
2022-03-10 Daysail Dory Pensacola.jpg (907.18 KiB) Viewed 6290 times
Seaweed2
Post by Seaweed2 »
Thanks for these vicarious day sails. Your writing and pictures are pleasant and read well. A good mix!
Jerry W
CD 28 Hull #46
wikakaru
Post by wikakaru »
2022-03-17 Dory Log 6.5-inch.jpg (1.86 MiB) Viewed 6274 times
2022-03-17 Daysail Dory Pensacola.jpg (904.12 KiB) Viewed 6274 times
wikakaru
Post by wikakaru »
2022-03-19 Dory Log 6.5-inch.jpg (1.49 MiB) Viewed 6271 times
wikakaru
Post by wikakaru »
2022-03-20 Dory Log 6.5-inch.jpg (2.29 MiB) Viewed 6268 times
Sea Hunt Video
Post by Sea Hunt Video »
Seaweed2 wrote:Thanks for these vicarious day sails. Your writing and pictures are pleasant and read well. A good mix!
Jim:
I agree 110% with Seaweed's comments. Excellent action photos. Excellent commentary. As I read your posts and studied the photos I had a sense of being there.
It doesn't hurt that you are sailing a gorgeous Ty Weekender. I sailed a Ty for about 4 years. She was special.
wikakaru
Post by wikakaru »
Roberto and Jerry,
Thanks to both of you for your kind words. I'm glad you are enjoying my little outings.
The Typhoon is a sweet boat in general, and I think Dory is a particularly nice Typhoon. I am very pleased to be her caretaker. My CD22 is more practical for short cruises and for when the breeze gets up, but no boat I have ever owned has been such a joy to sail as the Typhoon.
Smooth sailing,
Jim
