The Loos web site (https://loosnaples.com/how-to-use-pt-se ... ion-gauges) lists the following cable sizes for their gauges:tjr818 wrote:Jim,
You can get the Loos Pt-1 for about $100 and it will do both sizes.
Model Cable size
Model PT-1 Cable size 3/32", 1/8", 5/32"
Model PT-1M Cable size 2.5mm, 3mm, 4mm
Model PT-2 Cable size 3/16", 7/32", 1/4"
Model PT-2M Cable size 5mm, 6mm, 7mm
Model PT-3 Cable size 1/4", 9/32", 5/16", 3/8"
Model PT-3M Cable size 7mm, 8mm, 9mm, 10mm
I assume you mean that 3/16" cable will fit into the rollers of the PT-1 and you can get a reading on the top scale. But it doesn't look like there is a chart for the PT-1 correlating gauge reading to the breaking strength of the wire, which I thought was used as a sort of yardstick for initial tensioning. Is that correct?
--Jim
