Companionway drip.....drip.....drip
Frenchy
Re: Companionway drip.....drip.....drip
Post by Frenchy »
Jim, your project is coming along in your usual thorough style. I have one small idea to add. On a previous
boat, I had a leak in the companionway threshold area whenever there was a windy rainstorm.
It seems the water would run down the channel where the companionway boards slide and then run
up the slightly angled threshold into the interior of the boat. To fix, I epoxied in a 3/8" high strip of teak on top of
the threshold even with the interior face of the bottom companionway board. That stopped the leak.
I haven't had any leaks on my CD 33, so I'm leaving everything as is. - Jean
Frenchy wrote:Jim, your project is coming along in your usual thorough style. I have one small idea to add. On a previous
Thanks Jean. That's an excellent suggestion. Steve Laume noticed I did not have one last fall and was kind enough to fabricate one out of a piece of teak. I will install it in the spring after I have gotten all my bungs in place and the final coats of varnish applied.
SVR4
Location: 1978 CD 30 Ketch Hull #70 "Rogue Fore" Bayfield ON
Post by SVR4 »
Jim thanks for posting this. My CD 30 has a leak through the companion way as well. It is great to learn how other people are approaching this.
Chris
