Wow - that is impressive!! There were 70 mph gusts not too far west of us. I am envious (and apparently getting soft)rogergaby wrote:... I saw two TY's sailing on the Piankatank yesterday...
Roger
Typhoon Daysailer Mast Stepping
- mashenden
- Location: "Nautica" CD-36 #84, Ty-K #83, & CD-10 #1539 in Urbanna, VA. 4 other Tys in past
Re: Typhoon Daysailer Mast Stepping
Matt Ashenden
- I used to like boating and fixing stuff, then I bought a couple of boats and now I just fix stuff
Matt, I have a call into my friend. I think he used a fence post from Lowes and either an electrical conduit or a metal water pipe also from Lowes. One fit inside the other.
He will let me know details
Here is a post from Ensign Class forum:
Mike
--- Gary W <gartywood@...> wrote:
> Ensign spars sells them, however they are made form
> ensign mast
> extrusion and thus very heavy. We've uses old
> lightning masts that
> broke around the partners. they are pretty easy to
> handle. I have
> also seen some made from club 420 and blue jay
> masts. they look a
> little too flexy for my comfort in operation.
> You need two fixed stays to run to the upper
> chainplates (middle) and
> a stay to run through the tack fittign with line to
> the bow cleat.
> take up ont he forestay to tighten the whole rig.
> We have a 2:1
> purchase system and it's pretty easy to handle. We
> run the lifting
> line through on e of the deck blocks near the
> partners to the spin
> halyard cam cleat for safety and control.
> --- In EnsignSailors@yahoogroups.com, Victor Roberts
> <vdr@...> wrote:
> > Mike,
> > There's a good description, along with pictures at
> our Fleet 72 part of
> > the Saratoga Lake Sailing Club web site. See:
http://www.sailsaratoga.org/fleets/ensi ... _step.html
> > Vic Roberts
> > #150
> > Michael Holt wrote:
> > > I need to pull my mast and there is no crane,
> where I
> > > keep my boat. I have heard that I can use a gin
> pole
> > > to accomplish this task. I would like to get
> some
> > > feedback on the subject?
> > > Regards,
> > > Mike Holt
Expand Messages Author Sort by Date
Gin Pole
I need to pull my mast and there is no crane, where I keep my boat. I have heard that I can use a gin pole to accomplish this task. I would like to get some ... Michael Holt
captholt Nov 23, 2008
8:08 pm
Re: Gin Pole
Mike, There's a good description, along with pictures at our Fleet 72 part of the Saratoga Lake Sailing Club web site. See: ... Victor Roberts
vicroberts150 Nov 24, 2008
1:46 am
Re: Gin Pole
Ensign spars sells them, however they are made form ensign mast extrusion and thus very heavy. We've uses old lightning masts that broke around the partners.... Gary W
tailgunner496 Nov 24, 2008
5:27 pm
Re: Gin Pole
Gary, Good info! Thanks for your help! Mike ... http://www.sailsaratoga.org/fleets/ensi ... _step.html... Michael Holt
captholt Nov 26, 2008
12:33 am
Re: Gin Pole
Mike: Â Since I was desperate for a Gin Pole several years ago and could not locate an old mast to use, I went to Lowe's and bought 3 six foot steel end fence... Joel VerPlank
joelvp214 Nov 29, 2008
11:23 pm
Re: Gin Pole
Joel, I know exactly what you mean about trying to find an old suitable mast. I have been looking for a few weeks now. Thanks for the info. Mike... Michael Holt
captholt Nov 30, 2008
1:13 pm
Re: Gin Pole
Two 10-foot sections of 2" aluminum conduit threaded together also work well. Mike Scott ________________________________ From: Michael Holt... Michael Scott
m_d_scott Dec 1, 2008
1:43 am
Mike
> ensign mast
> handle. I have
> masts. they look a
> the bow cleat.
> We have a 2:1
> run the lifting
> <vdr@...> wrote:
> > Mike,
> > Vic Roberts
> > #150
> where I
> pole
> some
> > > Regards,
> > > Mike Holt
Gin Pole
8:08 pm
Re: Gin Pole
1:46 am
Re: Gin Pole
5:27 pm
Re: Gin Pole
12:33 am
Re: Gin Pole
11:23 pm
Re: Gin Pole
1:13 pm
Re: Gin Pole
1:43 am
- mashenden
Thank you!!! Apparently the link has changed, but that was enough info to figure it out.
To those interested, here is the link showing the Gin pole in use. http://www.sailsaratoga.org/content.asp ... e_id=67958
There is plenty of detail to get the point on how to do this on a CD Ty Model K. I have not found measurements yet, but it stands to reason that the Gin pole has to be about 4' longer than the distance from the cuddy top to the spreaders.
Any idea on what type of Gin is required? And can one substitute Rum?
Matt Ashenden
- mashenden
I wonder if using 2.5" PVC pipe and some additional mid-stays would do the trick? Cheap and readily available at any hardware store. I think I will give that a try when my time comes (think Spring, but probably Summer).
Matt Ashenden
Once upon a time I considered myself an "expert" on Gins - with a lot of practical "real world" experience under my palate.mashenden wrote:Any idea on what type of Gin is required? And can one substitute Rum?
- mashenden
I DO indeed care. I'll have to give it a trySea Hunt Video wrote:Once upon a time I considered myself an "expert" on Gins - with a lot of practical "real world" experience under my palate.mashenden wrote:Any idea on what type of Gin is required? And can one substitute Rum?If you truly care about your Cape Dory sailboat I would recommend Bombay Sapphire Gin. Possibly a few more "boat units" but worth it. I would not recommend substituting Rum - you will not be happy.
Everything in moderation, except sailing, which should always be done in excess.
Matt Ashenden
Matt,mashenden wrote:I wonder if using 2.5" PVC pipe and some additional mid-stays would do the trick? Cheap and readily available at any hardware store. I think I will give that a try when my time comes (think Spring, but probably Summer).
Maybe using PVC or whatever they are calling plastic plumbing pipe nowadays isn't a bad idea. It is pretty strong and a lot lighter than 2x4s or pipe. It can be drilled easily to install eyebolts for support. I would probably consider schedule 40 heavy wall pipe.
Maybe you started something.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- mashenden
Agreed. Sch 40 would be the way to go. I think I'll try that! But first things first... I need to fix the seats and install the teak cockpit floor. The boat is in great shape overall, but the cockpit plywood has some rot.Oswego John wrote:Matt,mashenden wrote:I wonder if using 2.5" PVC pipe and some additional mid-stays would do the trick? Cheap and readily available at any hardware store. I think I will give that a try when my time comes (think Spring, but probably Summer).
Matt Ashenden
The PVC pipe would snap since the loads are not simple compression. There are significant side pressures dynamically changing as you raise or lower the mast.mashenden wrote:I wonder if using 2.5" PVC pipe and some additional mid-stays would do the trick? Cheap and readily available at any hardware store. I think I will give that a try when my time comes (think Spring, but probably Summer).
John
CD25 #622
CPDE0622M78E
"You are not going to find the ideal boat. You are not even going to have it if you design it from scratch."
~ Carl Lane
CD25 #622
CPDE0622M78E
~ Carl Lane
John,
Oops. Back to the drawing board. Thanks for the info. I never did use PVC but the thought intrigued me. I had always used wood.
Again, thanks.
Again, thanks.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- mashenden
That was a concern, which is why I thought the additional mid stays would be needed. Has it been tried?jepomer wrote:The PVC pipe would snap since the loads are not simple compression. There are significant side pressures dynamically changing as you raise or lower the mast.mashenden wrote:I wonder if using 2.5" PVC pipe and some additional mid-stays would do the trick? Cheap and readily available at any hardware store. I think I will give that a try when my time comes (think Spring, but probably Summer).
Matt Ashenden
When I read about using PVC pipe it sacred me as well. It only comes in 20' lengths and once it begins to bend it will lose most of it's structural integrity. I would not want to be the one to find out this was not a good idea. Even if it did work once it might not always be the case.
You can get 2X4s, at least 20' long at a decent lumber yard. If you make a tee section out of two for each leg it should be strong enough so as not to worry. Aluminum pipe or angle would also work well. Even though the mast is not extremely heavy it could still cause a lot of damage to itself, the hull, you or all of the aforementioned.
As I always told my kids, be careful, Steve.
My friend bought a 10 foot metal fence post from Lowes and second pipe
I think it was a plumbing pipe about 10 feet
One fit Inside The other
He bore holes and ran a bolt through
I will get all the details
- mashenden
Wood or metal too will lose its structural integrity once it starts to bend. I'm not trying to be argumentative, just not one to dismiss an idea without fact, and thus far nobody has commented that it has been tried and found it to be unsuccessful.Steve Laume wrote:When I read about using PVC pipe it sacred me as well. It only comes in 20' lengths and once it begins to bend it will lose most of it's structural integrity...
Granted it seems reasonable to assume that Sch 40 plastic pipe would bend under less load than a comparable length of 2x4 or metal pipe, but the idea behind mid stays is to add a bit of additional support mid way up the Gin pole to ensure the PVC does not bend.
Put another way, would 10' of PVC bend sooner under comparable load than 20' of 2x4? That is the engineering question at hand
Matt Ashenden
- mashenden
I like the "one fit in the other" design for compact storage. Any details on what was used would be awesome. Thank you in advance.trapper wrote:My friend bought a 10 foot metal fence post from Lowes and second pipe
One fit Inside the other
Matt Ashenden
