Folks,
What about this five port fuel selector as a water tank selector:
http://www.conbraco.com/_products/78-12 ... 78-124.pdf
I've emailed the manufacturer to learn if there is some reason why this shouldn't be done. I'll post his response.
fresh water tank selector valves
five port fuel selector as water tank selector
Regards,
Troy Scott
Troy Scott
Re: five port fuel selector as water tank selector
I do not see how you could mount such a beast, since every side of it has a port except the top which is the handle. Since your plumbing would have to come from every direction, I dont think it would end up being a very tidy install.Troy Scott wrote:Folks,
Russell
I've tried various types of these manifolds over the years for garden purposes and find they always leak a bit.........granted, they are under household supply pressure. It would be fairly simple to cob something up with better valves out of pvc or copper tubing. I believe 1/2" vinyl tubing will slide over 1/2" copper.
________
Nash ambassador specifications
________
- Parfait's Provider
berthed Whortonsville, NC
OFF?? Is there an off position?
OFF?? Is there an off position? Is it also possible that there could be two tanks connected at once if the lever wasn't positioned carefully?
Keep on sailing,
Ken Coit, ND7N
CD/36 #84
Parfait
Raleigh, NC
Ken Coit, ND7N
CD/36 #84
Parfait
Raleigh, NC
Ken,
I would be very surprised if there weren't an OFF position. That's pretty standard for fuel selectors. The five port fuel selector looks like an airplane part to me, but I never came across it in aviation. The garden hose gadget would probably work, but I really just suggested it for fun. It IS funny looking, you'll have to admit. I do like the fuel selector, though. I think I could make that nice. But, as with Jeff and others, there are certainly more important things I need to tend to.
Regards,
Troy Scott
Troy Scott
