Restoring 18.5 typhoon wekender
Heavy Outboard Motor
Hi Serge.
I've been using a 5 HP Merc since the late 90s. It weighs a tad over 55 lbs, not counting the remote fuel can, etc.
So far, no problems.
But what you say is a very good point to keep in mind, something to pay attention to.
However, not to be controversial, I feel that a lot depends on what type of water you have to navigate in order to get to open water. Many sailors, myself included, have to put up with tidal currents and river flow currents. At certain times, they can be quite troublesome and something to reckon with. A smaller, lighter motor just won't cut it
For this and other reasons, some boat owners have to compromise on the size and weight of the motor they use. Granted, a 9 HP motor is a bit much, as was previously pointed out.
Just out of curiosity, I'm going to reweigh my motors tonight.
Best regards
Best regards
For the record, I just weighed my 5 HP outboard motors.
The two stroke weighs a tad under 50 lbs without fuel in the built in tank.
The four stroke weighs a touch over 55 lbs with no fuel in the tank. I never knew for sure. Always approximated the weight. Now I know.
3.5 Tohatsu, 2 stroke
Weights about 35 pounds with the long shaft and full tank. Pushes Sandy's Ty above hull speed and cruises about an hour on a tank (internal). The way I selected it for her was to go in a store and have her pick one up off the display stand.
Jim Davis
S/V Isa Lei
S/V Isa Lei
- RIKanaka
- Location: 1988 CD26 #73 "Moku Ahi" (Fireboat), Dutch Harbor, RI
Tohatsu 3.5hp 4 stroke
Tohatsu makes the 3.5hp in a 4 stroke now that weights about 41#.
Aloha,
Bob Chinn
Bob Chinn
whats next?? update to old post
ok guys heres an update on an old post all teak has been sanded down, which took forever there were 1/4 inch crevases in some areas!!! but now she looks beautiful!! i am painting the deck will the paint i need to use for that be the same as topside paint because i cant find any "deck" specific paint? also topsides dont need it but i thinki she would look beautiful with a green topside and a tan deck would it e worth it? and does antone have experiance wireing the lights on this boats because id like to ad in a cd player with speakers in the cockpit, but idk if the steel switch box in her is original.. oh and one more thing would any one have pics of their main sheet?? i know its alot but i would like her perfect before she goes in the water "hopefuly" by july thanks again
- David van den Burgh
Interlux's Interdeck
Try this. Interdeck is one of the easiest to apply and better performing finishes for nonskid surfaces.alsaleen wrote:i am painting the deck will the paint i need to use for that be the same as topside paint because i cant find any "deck" specific paint?
Paint
Interdek is easy to apply, also you can use Brightside (more colors) and just mix in the grit. Either works well. I prefer to use Brightside and grit, it seems to be more durable. Here is a photo of the Ty Daysailor my wife restored. She did it green with tan deck. Note all painting was done "roll and tip".
http://www.capedory.org/specs/TY-opendaysailer.jpg
Jim Davis
S/V Isa Lei
S/V Isa Lei
Paint
It was Brightside. She cut it a little with Penetrol and applied it by "roll and tip" There are several coats with 220 grit wet sanding between coats, even sheen over the entire surface. The trick is to watch your weather and not apply paint late in the afternoon. If dew gets on it overnight it will develop a mat surface. Do prep in the afternoon, paint the next morning. Wipe all surfaces to be painted with lacquer thinner just before painting. Be patient and careful.
Jim Davis
S/V Isa Lei
S/V Isa Lei
18.5 weekender
Alsaleen, I just purchased the 18.5 weekender and have some questions you may be able to help with. Can you tell me where your cockpit drains too? On my boat, there are no hoses draining the cockpit, just the holes. I can post photos if it would help you. Or if you can post photos of how yours is set up, that would be great too!
Tony
Tony
CD in FL
