John,john churchill wrote: my mbiggest -problem now is that i do not know which position my head is in, visions of slowly sinking keeping me from sleep. my head sits on a 1" piece of starboard. i wonder iof this is to raise it above sea level. until i read this i had notgiven it much thought, now i am giving it a lot. my last boat had a portapotty. i do not know which is more repulsive-emptying it or doing the holding tank. i sure will check my seacocks and flush valve when i go to the boat tomorrow, that is after they raise her, if need be. i keep telling myself that the marina would have called if she had sunk.
p.s. when i had SKUA surveyed last fall, i asked about an intake vented loop and was told it is unnecessary.
john churchill
If the fill water in your head rises to the rim and overflows, your head is below the waterline. The water will only rise to the level of the waterline. There are at least two boats in my marina that raised their heads above the waterline to prevent the accidental overflow. This has solved their problem. This method even works while sailing.
Of course when they leave the boat for the weekend, they do close all thruhulls.
To test where your waterline is, you can attach a hose (clear, so you can see the water)to the water intake and raise or lower the hose to see where the water stops overflowing. You would want to raise the head so the rim is at least at this level, but, higher is recommended to avoid spilling from sloshing when on a tack.
Donna Delahanty
maxg@fuse.net
