Good place to buy oil lanterns at a reasonable price?
Neil Gordon
Re: Heat From An Oil Lamp
Post by Neil Gordon »
Oswego John wrote:Three things are required for combustion; fuel, oxygen and temperature to the point of ignition.
The teak is the fuel. The surrounding air provides the oxygen and the proximity of the oil lamp to the fuel for a long enough duration just might be enough to raise the temperature of the fuel to the point of ignition.
See http://www.fpl.fs.fed.us/documnts/fplmisc/rpt1464.pdf for a paper on the ignifion of wood. Per the article, red oak took 20 minutes to ignite when heated to 180 degrees C. That's the heat of the wood, not the temperature of the source. Water boils at 100... is it possible to heat a teak bulkhead with an oil lamp to that point?
wingreen
fuel on the fire
Post by wingreen »
You forgot something in the "fuel" category, OJ:
The teak oil we slather on the wood to keep things looking nice is extremely combustible.
Jim Davis
Edgewater, MD
Post by Jim Davis »
In the liquid form. Once dry it really isn't. As long as the wood isn't too hot to place your hand on and hold it on the wood, there really isn't a combustion problem.
Jim Davis
S/V Isa Lei
wingreen
re: extremely combustible
Post by wingreen »
Light one of your old teak oil rags on fire after they've dried out and see what happens. I don't know the effect once it's soaked and dried into the wood, but I'm not sure I'd want to test it.
wingreen
Post by wingreen »
I like the way those old school lanterns look on a boat, too. I'm in the process of converting a few of them into electric lanterns w/ those little led lights they're selling. For $10 you can get a led unit that meets the 2 mi. visibility code.
Dick Barthel
Really inexpensive but a Dietz
Post by Dick Barthel »
If you're still looking here is a site for a real inexpensive Dietz hurricane lantern. I just ordered one for use in the cabin. If you want I'll let you know about the quality once it arrives:
http://www.cabelas.com/cabelas/en/templ ... stid=14106
oldragbaggers
Post by oldragbaggers »
eBay
Lance & Becky Williams
Happily retired and cruising aboard our dreamboat, Anteris
http://www.sailblogs.com/member/anteris/
https://www.facebook.com/oldragbaggers
