Hi folks,
I use a Johnson 8hp with a 25" shaft. Anybody out there using a 20" shaft motor? Is it sufficient to keep the propeller submerged under power in chop and swells?
thanks,
Erik
cd 25 motor survey-what do you use?
best,
Erik Schlein
Erik Schlein
Check the archives
Erik,
Search the archives on this. The topic of outboard engines on CD25s has been discussed at length many times. Click on the Search icon above and type in "CD25 Outboard" and you'll find a wealth of information on this topic. If you have any additional questions after reviewing what you find, don't hesitate to ask. Good luck and happy searching!
just searched the archive...call off the dogs
Thanks Carl. Plenty of good info already in the archive!
cheers-Erik
cheers-Erik
best,
Erik Schlein
Erik Schlein
