removing air from coolant
When my engine started overheating my first thought was to rev the engine as described in my manual to remove any air that may be trapped in the coolant. I just noticed on a diagram of my engine a little thing labeled "coolant air bleed", this may sound silly, but does this have to be open in order for the revving to remove and trapped air?
Remove Air From Coolant
VidaliA,
See reply under "Trapped Air"
