Just What Is - - -???
ray b
Post by ray b »
Scott MacCready wrote:Once again, I'll show my ignorance....
So, on a schooner, the aft most sail is the main as opposed to a mizzen on my ketch. The middle sail is the foresail, where my main is. And how about the sails most forward? Are they still jib and staysail and not foresails? A little confusing. :oops:
yes unless it is a staysail schooner
that rig uses a jib shaped sail behind the fore mast on a stay
some times with more then one sail inbetween the masts
if a sail is attached to a foremast it is a fore sail
if it is behind the foremast and on a stay it is a forestay sail
a gollywobber is NOT a working sail and used in lightairs mostly
and/or off the wind
a normal foresail on a boom is a working sail and used on most boats in heavyer air in place of a gollywobber
the mainsail is the biggest of the working sails on a boat
Oswego John
John Vigor Says
Post by Oswego John »
Ken,
Well, I'll be dipped. See, I learn something every day.
Wait a minute, hold on, not so fast. So what's the eighth, ninth and tenth ones called?
You could probably call them anything you want to. Who's going to disprove you. :D
Thanks for the info. In about ten years, I'll have most of the names down pat. (hopefully)
Mathias
jib names
Post by Mathias »
I haven't seen any mention of the jib sails, so I am adding my two cents. I worked on the schooner J&E Riggen out of Rockland, ME for a summer and during that time came to know that each ship had a slightly different set of names for the jibs.
Most of the Maine fleet flys at least two jibs. Some three, and I can't recall one with more than that.
Our captain called the foremost jib the jib, and the second one, the staysail. On other ships, the foremost jib was called the "outer" and the second one the "inner." Of course, you had to learn that with a Maine accent, making the first the "outa" and the second the "inna."
On ship's with an additional jib that was forward of those two (and flew higher than the other two - almost half way between bowsprit and masthead) was called the flying jib.
And who needs amusement park rides, when you can walk out on whiskerstays to the tip of the bowsprit while underway over the white crest of a ship's bow wake to unstop or furl the flying jib?
A summer residence I highly recommend to anyone.
-Mathias
Sunset, CD25
Lake Champlain
Re: Vigor Says...........
Parfait's Provider wrote:Seventh is a pusher.
As I recall there was one and only one seven masted schooner. With lack of precedent, masts were named Sunday, Monday, etc., etc.
Oswego John
Name Of Masts
Neil,
The four master I sailed on out in Kansas called it's masts Eenie, Meenie and Miney. Sorry, the fourth mast escapes my mind right now. I'll probably think of it at two o'clock tomorrow morning. (Nine bells)
fenixrises
Possibly another head scratcher 4 u... What is a mule?
Post by fenixrises »
Hi all,
Not the animal but the sail.
I know what kind of sail it is, how 'bout you folks.
Take care,
Fred
Didereaux
mules and such...
Post by Didereaux »
Unless I am way of my feed (once again) I believe the mule sail is a triangular version of a fishermans sail and is carried above the mainsail on multi masted gaff riggers.
Didereaux- San Leon, TX
Oswego John
Mules And Such
What's a mule. It's not an animal, huh? Hmmmmm. First thing that comes to mind is a heelless slipper. No, that's not a sail. Let's see.
So I cheat a little. (legally)
One of my look-um-up books says:
Naut. A large triangular staysail set between two masts and having it's clew set well aft..
Wish I had a picture.
Didereaux
here's a pic...
Post by Didereaux »
Guess they aren't just for gaffers. Here's a pic of a 'mule' on a ketch rig.
http://www.theyachtmarket.com/boat_for_sale_8187.aspx
Joe Mac Phee
Mule on a ketch
Post by Joe Mac Phee »
My Cape Dory 30 ketch has a mule. It is my favorite light air sail. Instead of removing the club footed jib and replacing it with the genoa in light air, I put up the mule. It is great for single handing. You can have four sails up and they are all self tacking. You just turn the wheel, a miracle occurs, and you are on the other tack.
The advantage is that most of the mule area is up high where it can grab whatever wind is available. The disadvantage is that most of its area is up high, where it substantially increases the heeling moment. I will fly it up to about 15 knots, and then it has to come down.
For off the wind, my ketch has a mizzen staysail. That sail is huge and I only fly it when I have crew. It is not my favorite sail. Both the tack and the clew must be moved to tack. The asymmetric spinnaker is much easier to use.
Maybe some day when the wind is moderate, and I have enough crew on board, it would be fun to raise them all. What a display of Royal Laundry that would make!
Sail on,
Joe Mac Phee
S/V Iolanthe
CD-30/K
Bristol, RI
Scott MacCready
Location: Previous Owner of CD30-ketch, CD26 #29, and CD25 #635 Hulls Cove,ME
Re: Mule on a ketch
Post by Scott MacCready »
Hi Joe, I have the mizzen staysail and have used it several times now. Once I figured it out, it's pretty easy to set single handed...well, not really single handed as I have the autopilot steering while I set it up. I run the sheet through a snatchblock off the aft end of the mizzen boom and tun the tack line through a snatchblock on a windward stanchion base. I use it only in light winds and it does block all visibility forward of the helm. I used it on the trip to Ocracoke last month but don't think anyone got a picture of it. I'd love to have the mule also but it'll have to wait til after a cruising spinnaker.
Joe Mac Phee wrote:My Cape Dory 30 ketch has a mule. It is my favorite light air sail. Instead of removing the club footed jib and replacing it with the genoa in light air, I put up the mule. It is great for single handing. You can have four sails up and they are all self tacking. You just turn the wheel, a miracle occurs, and you are on the other tack.
Sail on,
Joe Mac Phee
S/V Iolanthe
CD-30/K
Bristol, RI
