Outboard engine mount replacement: wood or plastic?
Pierre Gremaud
Location: CD 25 #146, Pin-Up and Sabre 36, Grayce, Belhaven, NC
Post by Pierre Gremaud »
The outboard mount on my CD25 broke this weekend. I think it was the original part: a venerable piece of solid teak.
The minimum size for a board out of which I could cut a replacement is 13 x 4 3/4 x 1 1/4. Does anybody know of a good source for an appropriate teak board?
I am also having second thoughts about using solid wood for that application (if you had a look at the old board, you'd understand why). I am seriously considering plastic alternatives such as starboard (possibly several boards put together to get the appropriate thickness and stiffness). Any thought/experience/advice would be greatly appreciated.
Thanks.
Pierre
CD 25 #146
White oak
Get yourself a nice chunk of white Oak. Much cheaper and easier to come by than a piece of teak that size. With oak you can afford to get a piece big enough to make a few bracket boards. When one gets a bit ratty, throw it in the fireplace and make a new one. It is probably easier to make a new one than refinish an old piece. Better yet make a couple right away while you are set up. I don't know much about the properties of "plastic" but you couldn't go wrong with oak, Steve.
Lang
Plastics?
Post by Lang »
I think most plastics sag when under constant weight, no matter how thickly laminated. Starboard is high quality plastic, but you should check with the factory about this.
I had replace my rotted away teak with "chengal" (a common boat building wood in asia). I was advised against using plastic by the business owner of a plastic supply shop.
Hope this helps.
