Specification sheet on CD330 is incorrect
Chris Reinke
Post by Chris Reinke »
Walt and others,
I have noticed the specifications listed on this site for the CD330 are not correct. It appears as though the data for the CD31 and the CD330 were intermixed. The CD330 should include the following:
LOA: 33'01"
LWL: 24'06"
Beam: 10'03"
Draft: 4"10"
Disp. 13,000 lbs
Chris.reinke@transamerica.com
Catherine Monaghan
Re: Specification sheet on CD330 is incorrect
Post by Catherine Monaghan »
Chris,
I've revised the specs of the <a href="http://www.toolworks.com/capedory/specs ... ">CD330</a> as indicated in your post.
Cathy M.
Chris Reinke wrote: Walt and others,
LOA: 33'01"
LWL: 24'06"
Beam: 10'03"
Draft: 4"10"
Disp. 13,000 lbs
catherine_monaghan@merck.com
Joe Wysong
Post by Joe Wysong »
Catherine Monaghan wrote: Chris,
Cathy M.
LOA: 33'01"
LWL: 24'06"
Beam: 10'03"
Draft: 4"10"
Disp. 13,000 lbs
Walt, Chris, Cathy, et al,
Let's get the specs on the 330 straight.
The LOD is 33'1"
The LOA is 35'4" due the addition of a bowsprit to the original 33 hull.
The sail area is 561 sq ft.
The displacement is 13,300 lbs.
Cape Dory built the first 330 in 1985 (three that year).
Take my word for it, I have a copy of the original building specs and history for the 330 courtesy of Robinhood Marine.
Joe
tgjournal@gestalt.org
bob loewenstein
Post by bob loewenstein »
Joe Wysong wrote: The LOD is 33'1"
Looking in the CD manual, it has the LOD as 33' 0 1/2"
It agrees with the rest of Joe's info.
rfl@yerkes.uchicago.edu
