Bent Boom
tony batchelor
Bent Boom
Post by tony batchelor »
Has anyone had success straightening a boom ? My one has a bent halfway along about 4 degrees not a lot but enough to affect the set of the sail
winthrop fisher
cd 22 "Easy Rider Sr" 84
Re: Bent Boom
Post by winthrop fisher »
Hi Tony.
i met a man years ago that bent his mast and he bent it back between two trees and it work.
but with his boom he took a torch to it just a little heat and straight his boom.
maybe it would work, fine.
winthrop
tony batchelor wrote:Has anyone had success straightening a boom ? My one has a bent halfway along about 4 degrees not a lot but enough to affect the set of the sail
Paul Kamins
Post by Paul Kamins »
Tony, I have the same problem and I plan to take it to a good machine shop to see if they can press it out. I'll let you know, Paul.
