Cape Dory 330 dimensions: something fishy in Denmark
Post by Russell »
When I look at the specs at this sight for the Cape Dory 330, (a) its linear dimensions (length, beam, draft) are identical with the 31, while (b) its mass dimensions (displacement, ballast) are identical with the 33. While I could believe that it has the same hull as either boat, I cannot believe it has this magical combination of both.
What gives?
Dana
Re: Cape Dory 330 dimensions: something fishy in Denmark
Post by Dana »
Russell wrote: When I look at the specs at this sight for the Cape Dory 330, (a) its linear dimensions (length, beam, draft) are identical with the 31, while (b) its mass dimensions (displacement, ballast) are identical with the 33. While I could believe that it has the same hull as either boat, I cannot believe it has this magical combination of both.
What gives?
___________________
How about 33'-1/2" LOD, 24'6" LWL, Beam 10"3", draft 4'10", disp 13300#, ballast 5500, SA 546 SF
Dana
darenius@aol.com
