I have a CD25 one of the plastic impeller blades on my knotmeter is broken and needs to be replaced any idea where I can get one and directions to replace it would be appreciated.
Thanks Rick R&R CD25
Loretarick@aol.com
Knotmeter impeller
Re: Knotmeter impeller
what kind of a knotmeter do you have? i have info about my travails with standard, but there is a happy ending.Rick Wakem wrote: I have a CD25 one of the plastic impeller blades on my knotmeter is broken and needs to be replaced any idea where I can get one and directions to replace it would be appreciated.
as with mine the knot meter is located below the water line and normally the boat must be grounded or raised in order to replace it. the impeller normally cannot be purchased separately and costs apporx 35-50$ depending on the model instructions are included in the replacement part normallyjohn churchill wrote:what kind of a knotmeter do you have? i have info about my travails with standard, but there is a happy ending.Rick Wakem wrote: I have a CD25 one of the plastic impeller blades on my knotmeter is broken and needs to be replaced any idea where I can get one and directions to replace it would be appreciated.
dasmike@aol.com
