Copper Oxide (?) Stain
One of my portlights on my CD27 evidently has a leak. I've never found a wet spot but the fiberglass cabin liner has green streaks running down from the base of the portlight. I'm not a chemist but I assume is copper oxide from the bronze. I'll remove and rebed the portlight next spring. Problem now is getting rid of the green stain. Before I put something on there that makes the stain worse or ruins the liner, does anyone have any recommendations for a cleaning product to remove the stain without damaging or staining the liner?
Warren Kaplan
Sine Qua Non
CD27
Oyster Bay Harbor, NY
Setsail728@aol.com
Warren Kaplan
Sine Qua Non
CD27
Setsail728@aol.com
Re: Copper Oxide (?) Stain
Hi Warren:Warren Kaplan wrote: One of my portlights on my CD27 evidently has a leak. I've never found a wet spot but the fiberglass cabin liner has green streaks running down from the base of the portlight. I'm not a chemist but I assume is copper oxide from the bronze. I'll remove and rebed the portlight next spring. Problem now is getting rid of the green stain. Before I put something on there that makes the stain worse or ruins the liner, does anyone have any recommendations for a cleaning product to remove the stain without damaging or staining the liner?
Warren Kaplan
Sine Qua Non
CD27
I get those streaks occasionally from two of my ports...I just spray a little Fantastic or Simple Green on it, let it sit for a minute or two, and wipe off....no problem with the liner. They don't bother me enough to rebed the ports yet...Not a simple job.
Clay Stalker
cstalker@cheshire.net
Thanks Clay,Clay Stalker wrote:Hi Warren:Warren Kaplan wrote: One of my portlights on my CD27 evidently has a leak. I've never found a wet spot but the fiberglass cabin liner has green streaks running down from the base of the portlight. I'm not a chemist but I assume is copper oxide from the bronze. I'll remove and rebed the portlight next spring. Problem now is getting rid of the green stain. Before I put something on there that makes the stain worse or ruins the liner, does anyone have any recommendations for a cleaning product to remove the stain without damaging or staining the liner?
Warren Kaplan
Sine Qua Non
CD27
Clay Stalker
Do you find any wet spots associated with those areas? I haven't and I've looked. The surrounding area isn't "mushy soft" either. Could this be anything other than a leak?
Warren
Setsail728@aol.com
Warren:
Could this merely be the rubber weatherstripping? The stripping on mine leaks unless I really tighten down on the dogs. I have found that a little WD-40 on the bolts allows them to get sufficiently tight without killing the fingers. Just a thought.
goldy@bestweb.net
Warren Kaplan wrote:Thanks Clay,Clay Stalker wrote:Hi Warren:Warren Kaplan wrote: One of my portlights on my CD27 evidently has a leak. I've never found a wet spot but the fiberglass cabin liner has green streaks running down from the base of the portlight. I'm not a chemist but I assume is copper oxide from the bronze. I'll remove and rebed the portlight next spring. Problem now is getting rid of the green stain. Before I put something on there that makes the stain worse or ruins the liner, does anyone have any recommendations for a cleaning product to remove the stain without damaging or staining the liner?
Warren Kaplan
Sine Qua Non
CD27
Clay Stalker
Warren
goldy@bestweb.net
Bill:Bill Goldsmith wrote: Warren:
Warren Kaplan wrote:Thanks Clay,Clay Stalker wrote: Hi Warren:
Clay Stalker
Warren
I think you are correct. I don't think the port itself leaks, just around the rubber....I find if I really reef it shut, it doesn't leak...spraying the dogs with something does help and keeps the green at bay....someone once suggested putting a little vaseline on the rubber to complete the seal...haven't tried that yet.
Clay Stalker
Warren...
I use silicone O ring grease on both the gasket and threads of the knobs. I got it at a dive shop...$6.00 for a lifetime supply. Has a thousand uses...waterproof and doesnt ruin the rubber like petroleum greases..
Boyd
s/v Tern
CD 30 MkII
Fort Lauderdale, Fla
Boyd@wbta.cc
Boyd
s/v Tern
CD 30 MkII
Clay Stalker wrote:Bill:Bill Goldsmith wrote: Warren:
Warren Kaplan wrote: Thanks Clay,
Warren
Clay Stalker
Boyd@wbta.cc
This isn't useful advice, but a response to your question mark. Copper oxide is black. The green stuff is probably a copper hydoxo carbonate compound.
Tom Keevil
sharphat@mind.net
Tom Keevil
sharphat@mind.net
Thanks Tom! As I said, I'm no chemist but I remember seeing old copper pennies, and copper fixtures of many types with some green oxidation compond. Patina if you will. Since bronze has copper in it, I assumed that's where the "green" came from via some chemical reaction. My main objective is to get it to "go away"! (HA!)Tom Keevil wrote: This isn't useful advice, but a response to your question mark. Copper oxide is black. The green stuff is probably a copper hydoxo carbonate compound.
Tom Keevil
Warren Kaplan
Sine Qua Non
CD27
Setsail728@aol.com
no vaseline on rubber
Clay:Clay Stalker wrote:Bill:Bill Goldsmith wrote: Warren:
Warren
Clay Stalker
DO NOT use vaseline on the rubber. Some types of rubber do not react well with petroleun jelly. Go to ANY dive shop and get a tube of silicon lube for o-rings. Use this on ALL your rubber seals. Makes them last forever.
randy.bates@baesystems.com
Re: no vaseline on rubber
Many thanks for the tip...I plan to go to a Dive Shop here in town and get some of this stuff today. This is, as usual, a board of very helpful folks.Randall T. Bates wrote:Clay Stalker wrote:Bill:Bill Goldsmith wrote: Warren:
Clay Stalker
Clay:
Clay Stalker
