Seacocks on the cheap...
Boyd
Post by Boyd »
Hi all... I am a Cheap...
My seacocks were all on the verge of locking up. Its been a year and the white Lithium grease was done. I am way to cheap to pay to have the boat hauled. So I set about to rebuild the seacocks with the boat in the water.
My first experiment involved the use of one of those pool toys sold as a "Noodle". Its a foam cylinder about 3" in dia. and 5' long. Comes in nice bright colors also. I took a swim and stuffed it into the sink thru hull. On the inside of the boat I then disassemble the seacock, lapped it, regreased and reassembled. Only a small quantity of water seeped in. Since the "noodle" was readily accessable from the rail no swimming required to remove..
On a roll from the success I then took on the engine raw water seacock. The intake is a rounded strainer with holes in it.. No "noodle" would work here. I took a small sink plunger and screwed a L hook into the end. Swimming again I hooked it on the screen and proceeded to rebuild the seacock. Not a complete success since there was considerable seepage. But the seacock is in the bilge already and the pump works.... :) 2 down...
Now completely confident I took on the 3 under the head sink. All water in this area drains directly to the bilge and the pump is working.... This time I am going to work without a net.. No more swimming... I am going to pull the thing and stuff a rag in the body of the seacock in one fell swoop. The quantity of water was ...well considerable. No way to lap these but they are in really good shape. The rag slowed the flow enough to get the plug greased and back in with one deft maneuver. Whew... Did all three and they work great...
I think I need to find a 12 step program before long....something bad has to come of this..
Boyd
Boyd@wbta.cc
Ken Coit
Re: Seacocks on the cheap...
Post by Ken Coit »
Boyd,
I hope you did this at close to low tide with the keelson very close to the bottom. As brave as you are, you ought to have been able to convince some yard to just let her hang in the slings overnight or over a weekend while you worked at your leisure.
Maybe there is a market for a yacht-sized floating dry dock?
Not my cup of tea, but mileage certainly varies.
Keep on sailing,
Ken Coit
Boyd wrote: Hi all... I am a Cheap...
Boyd
parfaitNOSPAM@nc.rr.com
Boyd
Post by Boyd »
My keel does sit on the bottom at low tide... and there is nothing as satisfing as the sound of a working bilge pump. It was a real good working test of the system...
Still floating...
Boyd
Ken Coit wrote: Boyd,
Keep on sailing,
Ken Coit
Boyd
Boyd@wbta.cc
Olli Wendelin
Post by Olli Wendelin »
Great job Boyd!
Anything you can do to stay out of a yard is a plus.
By my reconning you just saved $300.00 in yard fees, IF you can find a yard that will let you work on your boat. Add another $400.00 for the yard to do it. Who says boating has to be expensive.
I would have someone else around in case you run into a problem and need someone to keep their finger in the dike.
Now, if I can just borrow the noodle from the neighbors kid...
Olli Wendelin
BLUE MOON
Charleston, SC
wendelin@spawar.navy.mil
