Fairing compound (?) for transducer
Rich
Post by Rich »
I'm getting ready to prep the bottom for paint and I noticed the compound used to fair in the depth sounder transducer to the hull was looking a liitle ragged. What material would normally be used here? Would this be the same material used as a bedding compound for the transducer?
rpassmore42@hotmail.com
John R.
Re: Fairing compound (?) for transducer
Post by John R. »
Rich wrote: I'm getting ready to prep the bottom for paint and I noticed the compound used to fair in the depth sounder transducer to the hull was looking a liitle ragged. What material would normally be used here? Would this be the same material used as a bedding compound for the transducer?
Not knowing how deep the fairing needs to be in your particular case I normally use West epoxy and Microlight filler or Microballoons filler.
In shallow fairings I just use a couple applications of polysulfide.
There are a few commercial premixed fairing compounds you can purchase also.
