25D AP mounting ??'s
Post by Bill »
Hello to all
Well I am in the final stages of mounting a new tiller pilot. All I lack is drill & epoxing the tiller pin and the socket for the TP pin. I know how to do the tiller, but have a question about the starb'd seat process.
I know about placing a backing block under the locker lid and drilling the locker lid and block to accept the socket. But someone sent me a pic (at least I think someone did) about mounting a block behind the locker lid and drill just outboard of the gap between the seat and the the locker lid.
Please if you sent me a pic of your boat with this type of setup, send it again. Or comments about how best to accompolish this task.
FW
and Thanks in advance.
cd25d@clnk.com
Bob Ohler
Re: 25D AP mounting ??'s
Post by Bob Ohler »
Bill,
Instead of mounting the outboard end through the seat locker lid, or even behind it for that matter, I mounted my Navico TP100 into the teak coaming with through bolts and a back-up plate made by Navico. I was advised that this would be a better installation in that the strain would not be transferred to the locker lid hinges. That made sense to me and I took that guy's advise. I never had a problem with the coaming installation. Let us know how you make out with your installation.
Bob Ohler
Bill wrote: Hello to all
FW
Mike Nesja
Mounting a SIMRAD TP-30 on a CD25D
Post by Mike Nesja »
Bill,
We were not the ones who sent you a photo earlier, but we did install a SIMRAD TP30 Tillerpilot in our CD25D "Wielewaal" (1982-Hull #45) this summer.
Following the SIMRAD instructions as closely as possible, we ended up with the pin-cup mounted (with 3/4" hardwood backing) in a hole drilled through the starboard locker lid, perhaps 1 1/2" or so forward of the aftmost (I think, I don't have a photo) hinge, and about 1 1/2" or so in from the outside lip of the lid. This places the pin-cup above the right rear corner of the shallow locker tray area. The only slight problem is that this is a little close to the outer moulding around the tray, so we ended up with drilling a slight indentation in the tray moulding to make a little room for the pin-cup on the underside of the lid. The pin-cup is fully expoxied in place where it passes through the locker lid and partially epoxied (say 75% of its circumference) where it passes through the hardwood backing.
We also epoxied a shallow, wedge-shaped hardwood collar around the pin in the tiller, since, with the pin inserted and epoxied in a vertical hole drilled at the correct point on the tiller, a fairly large portion of the pin was out of the hole.
The good news is that it all works fine as installed.
nesja@aol.com
