After just having the teak re-done on my CD30 it is already breaking down on the surfaces with most exposure to the sun. I have considered Cetol, going gray (to match my hair) or another product I have seen advertised called Bristol Finish. They claim easier application and longer life than varnish, anyone have experience with this product?
It even looks like it can be applied over the exsisting varnish.
Jim Heavin
CD30 Lady Sandy, Lake MI
heavinj@kiva.net
Teak-Bristol Finish
Re: Teak-Bristol Finish
I haven't used Bristol but would like to hear of any experiences. I have used Cetol and there are several reviews in Practical Sailor ranking it 1 or 2 for the semi gloss finish. The gloss finish , according to PS does not hold up as well. They also have a new shade out that is very attractive but I have not heard of anyone using it nor have I seen any test results. I've used Cetol for years with great success. Needs 4 coats and touchups (for scrapes)througout theJim Heavin wrote: After just having the teak re-done on my CD30 it is already breaking down on the surfaces with most exposure to the sun. I have considered Cetol, going gray (to match my hair) or another product I have seen advertised called Bristol Finish. They claim easier application and longer life than varnish, anyone have experience with this product?
Jim Heavin
year to be successful. Covering in winter also helps. minimum of 2 years if ignored.
fracaron@earthlink.net
Ron -
You like 4 coats of Cetol? Almost everyone I talks to recommends 3 coats, and I think the label calls for 3. My question is, is there some minimum number of coats required to create a barrier that will last at least one whole season? I tried 2 coats, but it's already crazing in places after a couple of months.
cscheck@aol.com
cscheck@aol.com
Jim,Jim Heavin wrote: After just having the teak re-done on my CD30 it is already breaking down on the surfaces with most exposure to the sun. I have considered Cetol, going gray (to match my hair) or another product I have seen advertised called Bristol Finish. They claim easier application and longer life than varnish, anyone have experience with this product?
Jim Heavin
Look in the archive messages for "Bristol Finish" and "Honey Teak" messages to review remarks made by several of us whom have used both these very similar products and note the comparisons.
I don't think you can go wrong with either Bristol Finish or Honey Teak. Both are acrylic urethane finishes, Bristol Finish is clear with a very slight tint to it. Honey Teak is darker. Honey Teak is more expensive. The H.T. application is slightly different and more involved than Bristol Finish application. Both are good products.
All teak is not the same. Prep is important to get the oil , grey color and mildew out.Then follow directions exactly. WQe all are in a hurry and try to cheat only to pay for it later. 3 or 4 doesn't matter if it is not preped properly.Also, if you live in NE you must cover it in winter.Chris Scheck wrote: Ron -
Jim, Earlier this year I refinished all the teak on board my cd 30 with the bristol finish.
Prep is the biggest time/labor consumer of all.
The bristol finish is a three part mix. You have a lot of control over viscosity,flow etc. with this product. so you can mix solution to match the weather/temp. for the ease of applictation.
the hardest part of application for me was the corners either vertical of horizontal finish tends to thin out at the sharpest edge soI used thicker solution( less reducer)on those points to build up a nice coat.
Avery good filter respirator is essential when using this product. with good ventilation. I prefered a windy day over still air.
The teak is stunning!! Practical sailors latest issue covers this topic but declines to speculate on longevity, test was for 21 months intact. for bristol finish.
Good Luck, Ben
btlandscapers@imagina.com
Good Luck, Ben
