Teak and Holly cabin sole. S/V Leoma
While waiting for haulout in December Im bored and decided to start on the cabin sole. I’ll start with the small section in front of the engine compartment. I bought a piece of Burmanese Teak and hard maple. They dont have holly anywhere. Teak is so expensive. A 7/8” x 5.5 x 80” was $200. The Veneer plywood came up easy. The contact cement they used wasnt stuck at all.
I ripped the teak to 5/16” thickness and 2.5” wide. The Holly( Maple) I made 5/16 x 5/16. I sanded the surfaces clean. I applied epoxy on all surfaces and put some thickened epoxied as i set the pieces in place. I found it easier to just do a few pieces at a time. When these set and dry. I’ll work on the other pieces
Re: Teak and Holly cabin sole. S/V Leoma
Looking good! I can't wait to see how it progresses.
Jeff
Jeff
Im following “ Refit and Sail” utube. I guess he works on a lot if Contessas.
Wow…nice work. I’m sure it’ll look fantastic when completed. Thanks for documenting so others can benefit from your project. Leoma must be happy!
Ill wait a couple days to sand and varnish.
I think I have enough material to refinish the section at the v-berth. If anyone remembers. I did a little exploratory work there a few months ago and covered it with pieces of scrap veneer plywoodWDM3579
I finished setting the pieces at the v- berth section. I wiil sand and finish next. I wonder what i should coat it with. It seems like varnish would be too slick. I don't know when I can do the main salon area. Its gonna cost about $500 for wood and more resin I made a couple mistakes. I made the white strips too wide at the galley area. I’m making the rest of the job a little thinner. Hopefully not noticeable except to me. It was not easy holding the pieces tight there is some gap between in a couple places. Here are the photos if the galley area again and the forepeak section. That bench locker is not attached so it will fit much tighter
See that hatch board in the head area. I don't know why there is a sump there its only 2” deep. Maybe they thought it a good place to shower and put a bilge pump. Any way I wonder how a teak grate would look like this pic. Probably not worth it But the plain board I have is not very good looking
