This board is back !!!
If you are here that's obvious ...
It was a difficult journey ... but we are back and running on updated software with a more robust backup routine ...
The "look" of this page may change slightly in the coming days/weeks/months (it's called "style sheets" but the functionality will be the same) ...
You need to register here for full functionality ...
ucp.php?mode=register
you should consider becoming a member of CDSOA proper here:
https://capedorysoa.org/content.aspx?pa ... _id=432709
Fred Mueller
Jerezana
CD 27 Narragansett Bay
Jerezana
Re: This board is back !!!
Excellent work Fred! This new software is simple to use…if I can manage to start a new post and add a photo…ANYONE can do it.
Yes ... It's the same software, just latest version with the generic style sheet. PHPBB
look here: https://www.phpbb.com/
If you post or reply you can insert, attach, or link to pictures and other files ... if you click on a posters name (either the OP or a respondent) you can send a PM. You can edit your posts with the little pencil icon upper right in your posts ... you can delete your post if it has not been replied to ...
Especially note the "search panel" is in the very upper right ... not down at the bottom as previously ... and there is a comprehensive search criteria panel under the "gear" icon next to the "magnifying glass" search icon
There are hover prompts over the icons in the message compose panel and a robust "attachments" tab just below ...
Most importantly I think we are in the clear for Board stability going forward ... this has distracted me from other CDSOA business for two months ... so now we (I) can get back to new business ...
Fred
Fred
Fred Mueller
Jerezana
Jerezana
Thanks so much, Fred! As a new and very enthusiastic Cape Dory owner, I am thrilled (and relieved...) that this font of knowledge is back. Thanks for all of your hard work on it.
All the best,
Peter
All the best,
Peter
WooHoo! Well done!
John Ring : )
CD36 TIARA
John Ring : )
CD36 TIARA
At first glimpse it is looking great. Thanks.
Great work! Thank you. I'll be posting again soon about some of my latest projects.
Ken Easley
Intrepid 9 Meter - Felicity
Southport Harbor, Connecticut
Is anyone else not seeing pictures? We're they lost or is it still a work in progress? Nice job . Thanks. Am I missing something ?
I’m not seeing photos either…they were there a couple days ago…
the look and feel is nice. fonts and colors good. glad to see the forum up and running again.
Thanks for your work! The website revival seems similar to boat ownership, just when you think you're done another project pops up !
Thanks Fred, you're the best!
Went for my third last sail of the season last Saturday. Sails and dodger are now off. Waiting to be hauled.
Walter
Walter
Walter R Hobbs
CD 14 hull # 535, Grin
CD 27 Hull # 35 Horizon Song
Lincoln, RI
Lincoln, RI
I had my last sail on Nov 4, 2023. Then removed the dodger and sails.
I'll post something soon on the small project to remove the eyebrows.
Ken Easley
