Did you get it working???
If not make sure that the output side is not clogged or crimped somewhere along the line. If so this would cause the pump to shut off due to reaching the set pressure. I>E> the system has reached pressure and is not call for the pump to turn on. This could possibly explain why it came on once if the pressure dropped a bit over time.
Keith
Need help with freshwater system
- Location: 1995 Robinhood 36 - Joan Wilder (née Miss Melis)
Re: Need help with freshwater system
I installed a new pump and it works now. I have a leak coming from on f the hose connections so I have to figure that out. But overall it was a good fix.
Jake
"Joan Wilder"
Robinhood 36 Hull #200 (#1 of the Robinhood line)
"Joan Wilder"
