Leoma update Throttle control
I thought I was just going to clean and lube this control but It is badly corroded. I ordered the replacement form Defender Marine . The replacement really looks not very heavy duty. I put the old one back in place in case I need to use it. I can't believe it still works. You wouldn't even know it's so bad . The replacement is Teleflex CH2100P.
- teleflex ch2100p.JPG (109.87 KiB) Viewed 180 times
- throttle exterior.JPG (146 KiB) Viewed 185 times
