CD 28-1978-#214 Hardware/Rigging Parts - Last Chance
chelininger
Post by chelininger »
Cape Dory 28 - 1978 - #214 Parts for sale
Vessel restoration ended prior to completion - original and replacement parts for sale.
If items are listed - they are still available.
Email chelininger@msn.com for details, etc.
Bronze items are either original or replacements from Spartan Marine. They have not been used and are ready to install. They are discounted from their original price and are further discounted from the current 2022-23 prices and most include shipping/insurance.
HARDWARE - Cape Dory 28 Original and Replacement Parts
Spartan Marine Bowsprit Stemhead base (S615)
Lower Bobstay Chainplate Assembly
See below for details on both.
Spartan Marine Bronze Seacock 1 ½" standard with handle and screw/washer/nut = Pipe size 1 1/2"(S636): last one available ($369.00 new) - $330.00
Solid bronze construction with proper UL listing. A turning key has a cast bronze handle attached to it with a stainless steel fastener. Shut-off stop ensures the user that the valve is in the closed position when required.
Spartan Marine hose adapter is grooved for positive hose clamping. The base has a female straight pipe thread so a Spartan thru-hull can be properly installed. Two drain fasteners are located to either side of the seacock housing and can be used to drain the valve during lay-up. The full-opening plug type seacock is easily dismantled for annual maintenance. ¼" x 12" x 12" G10 backing plate - used to back seacocks.
Hose Adapter thru-hull 1 ¼" (T752) - $115.00
Hose Adapter thru-hull 1 ½" (T753) - $125.00
Each comes with bronze screws/bolts/nuts/washers.
Cast bronze. Complete with flange nut for installation. Ribbed hose adapter holds hose securely allowing for double clamping. Threads cut for ½" Cape Dory Hull and G10 backing plate addition.
Spartan Marine Ports
14"x 5" with nice tinted glass & copper custom screen - Spartan Marine original to 1978 CD28 #214. Price depends on amount ordered. 6 available. See details/photos below.
Complete CD 28 Rigging Refit Bronze Eyes to Titanium Chainplates - $1150.00 includes shipping/insurance.
Allied Titanium Grade 5 (Ti-6AI-4V)
Complete CD vessel chain plates for transitioning from thru-deck to chain plates - see photos/details below.
CD28 RigRite Lifeline System - see below for details.
4 sets left- $165.00 for a set (1 stanchion, 1 base, 2 backing plates, 4 bolts/nuts/washers) and shipping w/insurance. $600.00 for all four sets.
Original Stainless Steel 5 ¾" Bow Chocks (2) - $80.00 - now $70.00
RIGGING - Cape Dory 28 Original and Replacement Parts/Parts useable on other make/models
RigRite:
Spartan CD-4 Masthead in good working condition. Sells new $829.00. Original. NOW $175.00 - shipping/insurance included, see photo below.
Cape Dory 28 1978 - Complete Spreader Set (base/tube/tip/boots/tape) - $240.00 shipping/insurance included - see details/photo below.
4" Spar Cast Aluminum Black Epoxy Coated PC - 2 available ($29.00 new)/$25.00 Use up to 3/8" line.
See below for details/photo.
Hayn Hi-Mod 5/16 wire x ½ Th. Compression Stud 1 available - ($48.00 new) $40.00
Hayn Hi-OD 5/16 wire x ½ pin Compression Fork 1 available - ($160.00 new) $120.00
Hayn Jaw Body Only Turnbuckles "tfb" Series 5/16" 1 available - $60.00
Hayn items are stainless steel and bronze in original packing.
Schaefer Block 30-04 02 Series/Cheek SS / Curved Base K-S3004 - ($ 35.00 new)/$30.00. See details/photo below.
New England Ropes VPC Performance Braid 86' with core to core eye splice, end whipping and Ronstan Flat headboard/ Halyard shackle ¼" - (new $125.00)- $80.00
See photo below.
Items located in North Carolina, will ship or, if in area, may deliver no charge. Most items shipping/insurance included. Multiple items discounted and accessories included.
chelininger
Re: Cape Dory 28 - 1978-#214 Hardware and Rigging parts for
Original bronze ports available.
Spartan Marine 1978 original.
New tinted glass and neoprene gasket.
14" x 5" oval port. 14lbs.
Custom Screens of Schooner Bay bronze/copper screens - not plastic Spartan Marine - included.
Costs new @ Spartan Marine $549.00 w/o shipping/insurance or bronze screen.
One = $450.00 with bronze screen and shipping/insurance.
Discount depending on amount purchased.
6 available.
chelininger
Complete Cape Dory 28 Rigging Refit Bronze Eyes to Titanium Chainplates - $1150.00 includes shipping/insurance
Shroud Chain Plates and Back Stay Plate - New - $1433.89 - here $1150.00 includes shipping/insurance.
7 Custom Chain plates 1 ¼" x 6mm x 10 inches long
1 Pack of 20 3/8" Flat Washer 0.062 Thick x 1" outside Diameter
6 Pack of 4 3/8"-16 x 1 ½" UNC Hex Head Bolt
1 Pack of 20 3/8" Lock Washer
5 3/8" Lock Washer
5 each 3/8" Flat Washer 0.062 Thick x 1" Outside Diameter
1 each 3/8"-16 x 1 ½" Fully threaded Hex Head Bolt
3 Pack of 10 3/8"-16 Hex Nut
Includes naval architect measurements for fitting chain plates and custom adjustment to your vessel.
Titanium rigging.jpg (1.4 MiB) Viewed 3251 times
Titanium chainplates.jpg (1.21 MiB) Viewed 3251 times
chelininger
Contact directly chelininger@msn.com please for further inquiries/purchase.
chelininger
Cape Dory 28 Lifeline System - includes shipping/insurance. See below
4 Lifeline Single 1" x 24" Stainless Steel Stanchions (Rig Rite) w/Flat Top and Brace Hole
4 Lifeline Rectangular Stainless Steel Stanchion Bases (Rig Rite single bail) (may be used on CD 25, 25D, 27, 28 and 33)
Heavy duty rectangular stainless steel 3 ½" long x 2 ½"wide x 3/16" thick with single bail and drain hole. Attached to deck with (4) screws.
Includes: 8 Stainless steel cut, drilled flat bars backing plates and stainless steel screws, washers, and nuts
Stainless steel Lifeline stachion bases with screws, washers and nuts.jpg (1.89 MiB) Viewed 3254 times
7 Stantions bottoms and backing plates.jpg (1.56 MiB) Viewed 3254 times
chelininger
Barlow Australia 15 Single Speed Winch - working, bronze/powder coated. Care instructions included.
$50.00 shipping/insurance included.
Original bronze single speed Lewmar #10 winch on original solid cast bronze Spartan Marine winch stand #10 (new $340 each).
2 winch combo, free Harken winch handle and shipping/insurance included. $625.00
or $325.00 each shipping/insurance included.
flyboy5724
Post by flyboy5724 »
Do you still have the complete replacement parts for converting chain plates to exterior and Bomar 100 20x20? Please call me at 912-341-9940. I may also be interested in more parts. Thank you.
chelininger
Boom is available at Sailorman, Ft. Lauderdale.
Original to 1978 CD28 #214.
Cleaned and powder coated in 2016.
Selling at Sailorman $250.00
Yes, they ship.
chelininger
Re: Cape Dory 28 - 1978-#214 Hardware& Rigging for Sale
Rigging parts: spreaders, original working masthead, original tangs - all cleaned, greased up and in good condition.
RigRite:
Spartan CD-4 Masthead - Heavy cast aluminum masthead assembly with 4 sheaves - (SP=083A)
Original masthead in working condition. Sells new $829.00. Original $250.00 - shipping included.
Cape Dory 28 1978 - Complete Spreader Set (base/tube/tip/boots) -
Spartan CD-4 Spreader Triangular base (SP-089) - 2 available (original used).
Spartan 1 ¼" OD Round Spreader Tip - SP=090T (used)
2 Spreader clear anodized aluminum 37" (new)
Perimeter Spreader Boots.
Includes Johnson Rubbaweld Rigging tape.
$240.00 includes shipping/insurance.
Tangs - Double shroud Tang w/ 3/8" bolt mount for use with 2 shrouds up to 7/32" diameter. Tang is 1" wide at top and 2 ½" wide at bottom and 6 5/8" long at bottom. 2 available - ($ 39.00 new each). $50.00 includes shipping/insurance.
chelininger
Re: Cape Dory 28 - 1978-#214 Hardware & Rigging for sale
Rigging items:
Hayn items are corrosion-resistant, stainless steel and bronze in original packing.
Working load 900lbs. 3 ½" long x 1" wide.
New England Ropes VPC Performance Braid 86' with core to core eye splice, end whipping and Ronstan Flat headboard/ Halyard shackle ¼" - $125.00 - now $80.00
Shipping/insurance included.
chelininger
Re: Cape Dory 28 - 1978-#214 Hardware & Rigging for Sale
Bowsprit Stemhead base (S615): 7 ¾" x 4" x 3/8" -
Fits neatly through a slot in a flat area of a bowsprit up to 2.5" thick. The stemhead is cast manganese bronze. Below the bowsprit is a hole to mount the bobstay wire. The stemhead has six mounting holes for 5/16" fasteners which thread into the cast backing plate. (New $288).
Lower Bobstay Chainplate Assembly (C183):
Cast bronze. Designed to accept lower end of the bobstay. Assembly includes aluminum backing plate and mounting bolt. Clevis pins not included. (New $140).
SMALL
Clevis size = 1/2"
Break strength = 10,000 lb.
Fastener = 3/8" Hex bolt
$350.00 for entire bowsprit-stay set includes shipping/insurance.
Stemhead separate.jpg (2.31 MiB) Viewed 1669 times
Sasjzl
Post by Sasjzl »
Hi, I live in the Raleigh/Durham area and have my 1982 CD30 Cutter at Oriental, NC, and I need a replacement stanchion with base that is the first on the port side. It looks like you are selling yours as a set as opposed to individually which makes sense.
I am new to this size sailboat and Cape Dory’s and I will probably have crushed stanchions in the future. If you still have the stanchions how much are you looking for for all of them.
Thanks very much,
Jim Lee
chelininger
The Items that are listed above are still available -
PLEASE message to my email = chelininger@msn.com directly, thank you! Will not respond to email over site (it doesn't work). Thank you :roll:
I accept cash in person and a personal check/postal money order if shipping.
Hello
Do you still have the exhaust flange. Is that for 2” exhaust hose?
Thanks.
Anybody there? Sent Pm and email but no response.
