Looking for a ty weekender mast or similar
Tescarim
Post by Tescarim »
Looking for a Typhoon Weekender mast. I have all of the hardware (spreaders/mounts, halyard exits, shroud attachment fittings, etc) so I can get buy with just an extrusion. Wouldn't mind the complete set-up or even partial. If you are reading this, and know of another boat out there that uses the same 3.75x2.25 extrusion please let me know. I would appreciate it greatly!
I’m in Michigan, but have connections on the east coast for delivery/storage.
Megunticook
Re: Looking for a ty mast
Post by Megunticook »
I replaced the original mast on my Ty Senior with a new Dwyer extrusion. After a little careful drilling and tapping you'll have a brand new mast.
kevin.kilroy24
Post by kevin.kilroy24 »
I have a mast from a Sea Sprite 22D in which i believe should have the same measurements as Ty22 senior. Both are Carl Alberg designs. Not sure if this would work for you or not being the Ty is 18'6" ?? Also shrouds spreader/ back stay/ for-stay/ turnbuckles/boom/mast step. Main sail & two jibs. May need to be rewired. If this can be of any use PM or Call/Text me 631-796-0949
