I have available port and Stbd Nicro Fico End Controls and Car for the CD 33 traveler. They're in usable shape.
The top plate on the car will have to be swapped for your fiddle block/plate assembly. The cars were cross-bolted
to the track, meaning you'll have to remove the track to install OR drill and tap the track for vertical screws.
The controls and car are available for whatever shipping and packing costs are at UPS. I'm hoping someone
with the old pin stops can use them. - Jean
End controls and Car, CD 33 traveler
- DSCN0166.JPG (494.13 KiB) Viewed 417 times
Re: End controls and Car, CD 33 traveler
Jean,
I'd like them. I'll PM you with the details. Thanks.
Jim, I sent you a P.M. The control blocks went out UPS today. Good Luck. - Jean
Jean,
I installed the "new" system today. Over the winter I'll have my dodger modified so the control lines will pass through to the cockpit. The top plate on the car was replaced with a forged eye strap from my old car which was a new replacement a few years ago. Works great! Thank you!
- image.jpeg (439.68 KiB) Viewed 342 times
Hi Jim, It looks great. I'm glad the controls were put to good use. Hopefully we'll run in to each other some day
(not literally) on Buzzards Bay or L.I. Sound. - Jean
