Just days shy of removing Yankee's winter cover and starting the usual routine of pre-season chores in late March, I was the victim of a serious head-on crash at the hands of an erratic driver and sustained a bunch of injuries, including a shattered right wrist. No fun, but thankfully not fatal for me as it was for the other driver. After orthopedic surgery, a long convalescence stretches ahead. So no sailing or even minor boat maintenance work for me this year. None. Instead, a long lay-up for my ship, probably 16 months in total. Bummer!
What issues does such extended dry storage present? I'm expecting to give the boat an airing and perhaps renew the desiccant and mothballs she gets for every winter lay-up. I thought I'd ask my mechanic for his advice on the engine. Keep batteries on trickle charger in the basement? Pump out diesel fuel? Sanitize bilge? Haven't faced this one before, so any and all advice from the sages will be welcomed! Jim.
Time Out for Yankee
- Jim Cornwell
Re: Time Out for Yankee
Jim:Jim Cornwell wrote:Just days shy of removing Yankee's winter cover and starting the usual routine of pre-season chores in late March, I was the victim of a serious head-on crash at the hands of an erratic driver and sustained a bunch of injuries, including a shattered right wrist. No fun, but thankfully not fatal for me as it was for the other driver. After orthopedic surgery, a long convalescence stretches ahead. So no sailing or even minor boat maintenance work for me this year. None. Instead, a long lay-up for my ship, probably 16 months in total. Bummer! Jim.
Wow
I cannot really offer any helpful suggestions about caring for your Cape Dory during your convalescence. I am sure others will quickly post with recommendations.
Get well soon
- mashenden
Wow - best of luck on getting better!!Jim Cornwell wrote:Just days shy of removing Yankee's winter cover and starting the usual routine of pre-season chores in late March, I was the victim of a serious head-on crash at the hands of an erratic driver and sustained a bunch of injuries, including a shattered right wrist. No fun, but thankfully not fatal for me as it was for the other driver. After orthopedic surgery, a long convalescence stretches ahead. So no sailing or even minor boat maintenance work for me this year. None. Instead, a long lay-up for my ship, probably 16 months in total. Bummer!
I would focus on keeping a charge on the batteries, either in or out of the boat as is allowable.
And making sure the diesel tank is full - Personally, I would not drain it. Ideally you want it full enough to reduce condensations, but not so full as to overflow when it heats up. Knowing that magical level is usually pure luck
[Edit] and do an oil and filter change.
It sounds like the water system is still winterized so no worries there.
Matt Ashenden
So sorry to hear of this mishap, and here's hoping for a speedy recovery. See the thread below from the Cruiser's Forum regarding long term layup. I found the post by "Cheechako" to be particularly helpful.
http://www.cruisersforum.com/forums/f55 ... 31051.html
Bill Goldsmith
Loonsong
Cape Dory 32 Hull #2
Loonsong
Jim,
Sad to hear of your accident but glad you are on the mend and will, if an extended experience, still recover fully. Good healing to you.
I stored Femme on the hard for two winters several years ago when my parents were in their last year of life. I did everything I normally do for winter storage with a few extra precautions
As for the mental maintenance, I needed to write a long "unbiased" review of the Cape Dory 33 over that year to stay sane. Also became addicted to sailing videos on You Tube. Still working on all that. The article is still not ready for prime time but the exercise served its purpose.
- -Double checked the frame and shrink wrap and extra taped critical sections where a tear could let a lot of snow and water in, reinforced where I thought it would help
-Refreshed the Bounce fabric sheets placed around the cabin to keep the critters out (Works great, trust me)
-Ventilation, ventilation, ventilation. If you think you have just enough vents in the cover, add a couple more for our 33 I use 12 vents and for the extra storage added two up high on the shrink wrap, Leave several port lights open where you know the cover is sound
-I second advice on filling the diesel tank to minimize condensation and of course adding Sta-bil.
-Made sure that no vinyl articles were left in full contact with the deck - throw cushions, gear bags etc. That seemed to have some bad reaction with parts of the decks that required extra cleaning and even discoloration
- Of course fogged the motor and antifreeze etc. pulled the water pump impeller (Normal winterization)
-Ran messenger lines up the mast (if stored up) for all halyards and signal lines, not just main, jib and spinnaker
- JWSutcliffe
Jim:
Sorry to hear about that unfortunate mishap.
I broke left forearm on a business trip in Russia in March 2014. Upon my return and attention by my favorite orthopedist, he asked me what my priority was as far as rehab. My immediate reply - launching Oryx and sailing!
Skip Sutcliffe
CD31 Oryx
CD31 Oryx
