Hatch gaskets
Re: Hatch gaskets
if you have the original Bomar hatches its 1/2" round EPDM. It assumes the flattened shape with use. Same as the opening port gasket. If you have the newer trapezoidal Bomar hatches they use a different profile gasket and you can get that from many sources if you google "trapezoidal Bomar gasket".
