I have a outboard which isn't working. The recoil for the pull cord is stuck. That can be worked around by wrapping the cord manually. But the motor isn't working. It was working a year ago. Probably ethanol gummed it up.
I'm willing to sell it on the honor system. You pay shipping (which we could do by Greyhound at not too much cost, probably about $65). Then see if you can get it working. If then you feel that it is of value, you can send me what you think it was worth. But if you end up spending a lot getting it fixed, then you can have it for free.
Evinrude outboard 4hp long shaft
- Calclements
- image.jpg (826.11 KiB) Viewed 286 times
- image.jpg (888.06 KiB) Viewed 286 times
- image.jpg (915.32 KiB) Viewed 286 times
- Calclements
Re: Evinrude outboard 4hp long shaft
It's a long shaft. Fine for a small sailboat, like a typhoon.
