I gotta say cutting the engine bed free with a Dremel was the nastiest, dirtiest, filthiest, dust choked boat job I've ever done. Glad it's done with. I ended up using the gantry again to apply upward force to the engine bed while driving wedges under the bed, even a after all the tabbing was cut away. With a few hundred pounds of pull, and a few hammer taps on a wedge, it popped free one side at a time.
With the engine bed out, I see the aft stb corner is worse than I thought. And, both lower tubes are rusted throughout on their inner sides. It looks like the engine coolant vent loop sprayed sea water back there for years before I bought the boat. There's no point in trying to save this bed - I'll have a new one made up using a more corrosion resistant material.
Jeff: The CG was aft of the lift point here too. I tried an engine leveler at first, but it took up all the lifting space above the engine and I couldn't lift enough to clear the oil pan over the bottom of the bed to move forward at all. After that, I just cut 1/4" chain to the required short lengths and shackled them onto the two lifting tabs and also around the fwd/port motor mount bracket. I set the lifting hook as far aft as possible - didn't quite hit the CG and the aft chain carried more than it's fair share of the load. This arrangement gave me a very low lift point and a solid three point base to keep it somewhat level. It worked great this way.
John
