Since most of the components were removed from my CD30K I have a few questions for the group.
1. When my bowsprit was replaced a windlass was added, which might present a clearance problem for the boom. I've also seen some systems that don't require a boom. Pros/cons? ie: is the boom necessary to provide enough outhaul tension?
2: Where should the solent attach on the mast (other photos of CD30K it seem 3/4 the mast. I will go back up when it's time to reattach the triatic (had to remove for hauling this season). Here is my current set up.
3: If I need a boom, where should I start looking, and the solent hardware?
Thanks OceansPoem for giving me inspiration!
Thanks in advance.
Adam
