Stan, this past weekend I installed an 8 inch access port in place of the 4 inch one. Gave decent access to all the through deck bolts but still a stretch when you are working alone. I've been removing all the through deck bolts and taping screws on my Ty and have been oversizing the holes in filling with epoxy to seal off any core.StanC wrote:I replace the 6" access port with an 8" access port on my Typhoon in order to install a traveler. With the 8" opening I could place nuts and washers on the bolts holding the traveler. I used the 8" template that came with the access port. Worked fine
StanC
New Typhoon Owner with Questions
- Location: 1977 CDTy Weekender #1423, Toledo, Ohio. Sailing Lake Erie, CDSOA #1651
