Hi All,
I found what is listed as a 1991 CD30. It has a head where the V berth should be, just like a 25D. Was the CD30 made as late as 1991? Any thoughts on this?
Jon
s/v Sovereign
1991 CD30?
Re: 1991 CD30?
Jon:Jon wrote: Hi All,
Jon
s/v Sovereign
CD made several of the "B" model 30, which had a layout similar to the 25D. Most were made in 85 and 86,I believe, prior to the 30MKII. The boat you are referring to, I believe is explained as the last 30 hull custom built by Robinhood in 91. The hull was left over, and they made several changes, including a keel stepped mast (normally, it would have been deck stepped, with a compression post.
The layout is geat for two folks.
Joe
sankey@gulftel.com
