Well, the weather was not ideal for varnishing, so while I did sand the companionway teak this past weekend, it did not get sealed. I also ran across the first surprise... the hatch was more seriously damaged than first thought. The fire caused it to delaminate so it will take a bit more than just a layer of epoxy and a paint job to fix it. Still not a big worry - very doable since the outer skin was not compromised, so I can simply strengthen it rather than replace it.
Most of the battery cables are installed, and some of the DC branch circuits (port side) are now traced and labeled in preparation for installing the DC panel (Blue Sea 8377).
The AC panel arrived. I went with a Blue Sea 8412 - a horizontal layout that will go in the area above the quarter berth (kudos to Russell for that idea). Its a perfect location if the goal is to separate the AC and DC systems.
With much of the burned areas sanded and sealed, I took it as a win to detect a faint smell of the holding tank rather than soot while going to sleep. Ahhhh, its the simple things in life
Matt Ashenden
Oh, and please check out my webpage...
http://VaRivah.com
